Very Foggy Headlight Lens
Old Jun 29, 2009 | 05:52 PM
Lotus Man's Avatar
Lotus Man
Default Very Foggy Headlight Lens
Hi,
How have you guys been clearing up your road rash-induced foggy headlight lamp pods? I thought about using some polishing compound or a fine-grit polish paper/cloth. But I figured that the best those things would do is create shine on a opaque surface, and not make a clear lends -- *clear*. If anything, any fine polish would only make the lamp pods even more foggy.
What to do?
Does any of this stuff actually work (?):
http://www.rd.com/39716/article39716.html
What brand and version of the polish compound works best? Ideally, I don't want to go through several stages of polishing steps -- I just want to squeeze out the subject compound on a piece of cloth and wipe until clear -- any company makes this?
Clearly this only works on the Z's plastic lens and not on glass, right? Or do they make compounds for both? I just need the plastic version.
Thanks!
Old Jun 29, 2009 | 06:50 PM
LVZ053's Avatar
LVZ053
Tons of Foggy\Hazy\ Headlight trends already.
I used Plastx and a buffer and mine came out golden.
Here is an after shot. Did not get a before shot but I live in Vegas where temps hit 120 degrees so you can imagine the damage it did.
Old Jun 29, 2009 | 06:52 PM
The problem with headlights is that condensation inside the light collects dust. Polish will improve the outside, but of course the inside remains dirty.
Old Jun 29, 2009 | 08:26 PM
maXmood's Avatar
maXmood
Under Boost!
i got couple of threads pointing out the steps. check the DIY for one "foggy headlights", and other should be found in this section "Clear Coat Removal".
Old Jul 23, 2009 | 08:39 PM
rmcheat's Avatar
rmcheat
You should check out Headlight Restoration Service ( www.hrslights.com ). I have had excellant luck using them. every headlight i receive looks brand new, and free U.S> shipping. I hope this helps.
Old Jul 23, 2009 | 10:28 PM
spinviper's Avatar
spinviper
I just did mine, SHine !!!!
http://www.youtube.com/watch?v=GsHHB...e=channel_page
Old Jul 24, 2009 | 05:43 AM
rmcheat's Avatar
rmcheat
Tried that one. My headlights looked worse than before i started. Sorry!
Old Jul 24, 2009 | 07:45 AM
spinviper's Avatar
spinviper
Yeah If you sand it. It will look worse, you need rubbing compound and plastic polish.
Old Jul 24, 2009 | 07:47 AM
spinviper's Avatar
spinviper
Yeah Turtle robbing compound ( red one) and PlastX work great
Old Jul 24, 2009 | 02:04 PM
firefighter85's Avatar
firefighter85
use plastx! awesome stuff
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
