Parking light bulb replacement.
Old Jul 30, 2009 | 11:22 PM
User 42426's Avatar
User 42426
Default Parking light bulb replacement.
I know sylvania carries stealth light bulbs. But I was wondering if any vendors or members on here know where I can get some led bulbs that do the same thing. I want the led to be white when off, but turn yellow when using the blinker. Please let me know, thanks.
Old Jul 31, 2009 | 05:36 AM
Brrcats's Avatar
Brrcats
well are you talking about the parking light, or the turn signal, your post references both.
if you are talking about the turn signals, its a 992 (7440A), pretty sure, but you'll have the fast blinking light thing going on unless you install resistors as well.
if you are talking about the parking light (the small light next to the high beams), its a 168. use the (194 168 W5W 2825 Focused Lenses)
both can be found at http://autolumination.com/
Old Aug 2, 2009 | 06:53 PM
User 42426's Avatar
User 42426
Oh. I meant to talk about the turn signals. So if I were to get LED bulbs, they would blink really fast?
Old Aug 6, 2009 | 07:02 AM
garu's Avatar
garu
Yes they would blink super fast.
That's why you need resistor on each side to take off some load. LEDs use less watts.
Old Aug 13, 2009 | 10:39 PM
Abejundio's Avatar
Abejundio
Pull bonnet up, take a small screw driver and pull grill off then pull off lower headlight surrounds. These have four connections that need to be slide outside of the car. Remove and place the parking Light Bulb .
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
