need help, driver window has gremlins!!
Old Aug 17, 2009 | 05:46 AM
350ezy's Avatar
350ezy
Default need help, driver window has gremlins!!
So I started having problems with my driver window about a month ago. I would put it down and then I would get stuck for no reason. So the first time it happened I removed my door pannel and the pannel with the window regulator and everthing looked ok. I put it back together and it worked for a few weeks, sometime it would get stuck down so I would open and close my door a few times and then it would work. Now its stuck up and it doesnt go down when you open the door or use the unlock button on the key pad.
Has anyone had this problem before? Its slowly making me hate my z so I need to fix it asap!
Old Aug 17, 2009 | 06:34 AM
Subdermal's Avatar
Subdermal
First thing I would do is double check all ur connections and solder if u are able. I know the window motors are known to have issues but that's where I would start
Old Aug 17, 2009 | 07:28 AM
Armitage's Avatar
Armitage
My passenger side window has rolled up and down slower than my driver side for like two years. I think the Nissan window motors have always had issues.
Old Aug 17, 2009 | 08:03 AM
350ezy's Avatar
350ezy
I checked everything. On the window motor there isnt anything that you can resoder. I was wondering if the driver switch controls the movement of the window when you open/close the door? I work at an auto upholstrey shop and this is the first time I have ever seen anything like this and go figure it would be on my car.
Old Aug 17, 2009 | 08:13 AM
mariar508's Avatar
mariar508
You will need to replace it. Happened to the passenger side window on mine, once it stopped working completely i got it replaced. Now the driver side window is acting up. I'll probably have to get that one replaced as well..... It's just a matter of time. The window motors on Z's are beyond horrible. You'll just have to live with them.
Old Aug 17, 2009 | 12:56 PM
350ezy's Avatar
350ezy
I figured it was the probably the window motor. This is bring back bad memories of my jetta and all the window problems they had. Thanks for the help I will price one out and give it a shot.
Old Aug 17, 2009 | 04:25 PM
DFW 350G's Avatar
DFW 350G
The window motors are a BIG problem. Appearently the dont have an opening in them to let dust and other things filter out, then they end up badly corroded and the motor loses its connectivity. Either clean it or replace it, but it will continue to happen.
https://my350z.com/forum/maintenance...dow-motor.html
I am currently searching for a possibility of replacing it with a window motor from another Nissan product (NOT a 350Z) since it seems like every year has had the same problem (and part number). I know it would take some fabrication, but anything is better than dealing with this problem over and over again.
Old Aug 17, 2009 | 04:29 PM
350z00m's Avatar
350z00m
lol... thats exactly whats happening to me right NOW! lol.. my shop says its the motor.. and i trust them... my window would get stuck then i would have to bang on the door panel to make it work. sometimes i have to pull the window up to close it! hahaha....
Old Aug 17, 2009 | 04:31 PM
jduet's Avatar
jduet
I just started having these same problems two weeks ago on my '08.
Old Aug 17, 2009 | 07:58 PM
Blck350z's Avatar
Blck350z
......my passenger side goes up slower than my drivers.....
I guess I should've stuck my Hyundai
Old Aug 18, 2009 | 06:38 AM
350ezy's Avatar
350ezy
Wow has anyone actually taken the pannel out and looked at the way the window works. Iam sorry but thats the dumbest thing I have ever seen on a car. Its used a pulley system with cables and crap. Its set up to fail after a few years so Iam not surprised to hear other people are having the same problem. I guess Iam gonna be doing alot of these in the near future.
Old Aug 19, 2009 | 08:00 PM
SILKZ03's Avatar
SILKZ03
Dude...me too. The passenger side window sometimes get all the way down or all the way up and I have to bang on the door panel for it to work...WTF. Now I know!
Old Sep 25, 2009 | 03:11 PM
az240z's Avatar
az240z
After reading everything I'm going to replace the motor. the question is do I buy a reman from auto zone for $170.00, buy a reman from Ai Cardone, which is auto zones supplier for $103 + shipping, or buy one from ebay [oem] for $200 including shipping??
I'm leaning to the oem as everyone has had problems from the ramans. Anyone have any thoughts or suggestions as to what dealer I can buy these from.
Old Sep 25, 2009 | 03:53 PM
Chomorro's Avatar
Chomorro
Get it from Coz@CZP he is a vendor on here. Not going to post the price since prices always change,but he was the cheapest i could find for new . Just pm him.
Old Dec 25, 2009 | 07:28 PM
TARGET350Z's Avatar
TARGET350Z
Any luck with this idea?
Old Dec 28, 2009 | 01:44 AM
GHOST1207's Avatar
GHOST1207
I am having the exact problem you are. I also noticed when it does work, the window slowly creeps up/down and the motors whirs a really low sound, almost like the motor is about to die, or something is making it difficult for the window to come up/down. Another thing i noticed, whenever I press the window switch, sometimes it clicks 2-3 seconds after i let off of it when it should make the clicking noise right after i let off of it and every once in a while it doesn't click at all. I'm thinking mine has to do with the window switch. Should I try disconnecting the battery over night to let the car relearn the window position? I was thinking it might be off.
Old Dec 28, 2009 | 05:01 AM
rich350z's Avatar
rich350z
Would a window motor and regulator from a 370 work on a 350? or would you still have the same problem?
Old Dec 28, 2009 | 05:27 AM
Jay'Z's Avatar
Jay'Z
read my DIY or hate life with shitty window..
Old Jan 15, 2010 | 12:21 PM
GHOST1207's Avatar
GHOST1207
Currently in the dealership getting the driverside window fixed and both my heat warmers, all under warranty, will post back for results.
Old Jan 15, 2010 | 11:59 PM
GHOST1207's Avatar
GHOST1207
Window motor was bad as I have suspected, working perfectly now. Kind of feels weird having it work now.
lapham3
Oct 7, 2022 03:15 PM
Siqcology
Sep 18, 2019 01:45 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
