Headlight went out
Old Sep 13, 2009 | 02:03 AM
MrWatchDawg's Avatar
MrWatchDawg
Default Headlight went out
OK i have a situation. I had condensation in the headlight in the car and now my right bulb went out. I am putting a new headlight on but the question is do I need to replace the whole HID kit or just the bulb?
someone pleaseee help!
Old Sep 13, 2009 | 04:32 AM
raycs7's Avatar
raycs7
There was a guy with the same problem with his aftermarket headlight.
Bulb was OK but he fried the ballast twice.
Test the bulb in the other light.
Old Sep 13, 2009 | 07:32 AM
Dark8lue's Avatar
Dark8lue
damn dude since we are on the topic- if u have eyelids and a bulb goes out, its stil covered under warrenty right? and.. they can jus take the bulb out of the back of the headlight so they dnt f up my lids? i hope so..
Old Sep 13, 2009 | 09:04 AM
Remove the old headlamp and inspect bulbs, connectors and harness. If any items show deterioration or carbon deposit from burning - replace.
I would not risk damaging a new headlight with a faulty bulb.
Consider that you can do troubleshooting by connecting everything WITHOUT the headlamp housing assembly in place.
NOTE: Disconnect battery during assembly and disassembly.
Old Sep 13, 2009 | 10:34 AM
MrWatchDawg
so basically disconnect the bulb and try it on the other side? How much does the ballast run for?
Old Sep 13, 2009 | 10:58 AM
Hydralisk's Avatar
Hydralisk
do you still have the fender well plastics in place or did you ever paint your headlights?
Sometimes water will hit the back of the ballast and Nissan built a failsafe into it.
When the ballast is filled with water, it will simply turn off the entire headlight assembly protecting itself. You need to get the water out of the ballast if this is the case.
Its been a long while but what I *think* I did was shake all the water out of the ballast once I got it off the assembly, then put only the ballast in the oven (or on the driveway on a nice BRIGHT summer day) so you can evaporate the rest of the water out.
It always worked for me.. or you may need a new bulb :/
for the oven, i think it was like 200 degrees for 10 minutes, cool down, test, repeat if didnt work. been a while so not certain as to temp.
Old Sep 13, 2009 | 11:06 AM
cheshirecat79's Avatar
cheshirecat79
Like Hydralisk mentioned, I'd suggest you take out the headlight and remove the ballast. Dry it out, as there's probably water where the plug is. The headlight might start working again, but you'll need to figure out the condensation/leaking problem.
Old Sep 13, 2009 | 11:11 AM
MrWatchDawg
well no i didnt ever paint my headlights or anything. I went to my bodyshop guy and he said that because of Texas heat prolly one of the seals melted and thats where teh condensation got in from.
I was going to order these http://cgi.ebay.com/ebaymotors/NISSA...ht_4614wt_1165
I wanted to get a set of 8000k bulbs anyway. You think those are good
And than SINCE i cant find ANYONE with a right headlight and junkyards charging beastly for this i am thinking about ordering these. http://cgi.ebay.com/ebaymotors/2003-...ht_6441wt_1165
Also whats the difference between D2R and D2S
Old Sep 13, 2009 | 11:14 AM
cheshirecat79
It's probably the ballast, not the bulb.
Old Sep 13, 2009 | 11:18 AM
MrWatchDawg
found one which is
http://cgi.ebay.com/ebaymotors/Nissa...ht_2519wt_1026
should do the trick? Thing is I am going to the body shop to get the headlight replaced so might as well get the bulb and ballast thing done same itme
Old Sep 13, 2009 | 11:27 AM
Bulbs from China are not for me. You get what you pay for. See: http://www.sylvania.com/LearnLightin...HIDTechnology/
Old Sep 13, 2009 | 12:32 PM
MrWatchDawg
understandable. So which ones should I get than?
Old Sep 13, 2009 | 03:22 PM
Hydralisk's Avatar
Hydralisk
Umm I just wanted to say
"CURSE THIS SITE!!!!!!!!"
After I sent my reply, I went outside, knowing my headlights were perfect even though it rained. I turned it on and the left one makes a loud brrrrr sound. My ballast is wet again.
Again, Curse this site..............
lol. Good thing its going to be a track car I guess.
Old Sep 14, 2009 | 07:03 AM
MrWatchDawg
ouch lol maybe we can get a 2 for 1 deal haha
Old Sep 14, 2009 | 08:59 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Get 6000k... not 8000k.
...Unless you want to rely on streetlamps to see shet while driving at night.
Plus, 8k and up = rice imo. Stick with what looks FACTORY hid.
I can tell 8k right away while blinding me only to see they are on a 86' Cutless or 93' Ford Ranger when they pass.
Old Sep 14, 2009 | 09:47 AM
MrWatchDawg
what does a stock TL or TSX have. thats the color im looking for even the beamers
Old Sep 14, 2009 | 11:36 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Its not the "K" that makes those car's HLs look like they look, its the type of Projector lens that makes all the difference in how they appear.
Most factory HID units (if not all) use in the 4000K range...
Thats because 4K range has been proven to be the closest to imitate actual sunlight. Anything in the 5k and up range and your light ouput decreases, although it looks brighter from the outside.
In actuality, the driver can see much less with 8K than one with 4.3K. All they accomplish by adding an 8K system is to tell everyone "look, i added a cheap HID kit" and to blind everyone on the road in doing so.
Stick with Factory, tats what all the bemmers and Mercedes have, and thats what your cool Nissan sports car came with as well.
Old Sep 16, 2009 | 07:03 AM
MrWatchDawg
makes sense now
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
