Stained acrylic gauge
Old Sep 15, 2009 | 11:53 AM
doncesar's Avatar
doncesar
Default Stained acrylic gauge
Hi, ok so I was trying to clean the 3 gauges with the stuff that is used to clean LCD screens, as soon as I wipe the multigauge it got all stained and whitish, I didnt want to rub it any further without first asking for advice, what can I do to clean it?!
Old Sep 15, 2009 | 01:28 PM
I do not see anything.
Old Sep 15, 2009 | 01:45 PM
redman333's Avatar
redman333
What three guages.
Old Sep 15, 2009 | 08:04 PM
doncesar's Avatar
doncesar
the three gauges that read speed, oil and volts, guess Im not getting help from here
Old Sep 15, 2009 | 08:21 PM
lbz's Avatar
lbz
It helps if you post pics when referring to something that is seen. I would try plastic polish, like that used on headlights or maybe rubbing compound with a wet rag. Sounds like there might be something in the cleaner that burned the plastic.
If you can't get it cleaned off, I recommend checkinghttp://www.slidegood.com for a used one. The dealer will probably charge in the range of $150 for a new one.
If you end up needing to replace it, please PM me, I will buy it from you. I have a use for it.
Old Sep 15, 2009 | 09:04 PM
doncesar's Avatar
doncesar
thanks!
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
Calinismo350z
Sep 14, 2015 04:04 PM
