370z side lights on 350z
Old Oct 5, 2009 | 08:21 AM
james-z33's Avatar
james-z33
Default 370z side lights on 350z
ive installed all the wires and ran the lights to the parkin lights and now they are not workin ive checked all fuses and not one blown...... now i get in my car today and the turn signals on my dash dont light up and my parkin lights dont come on.... theres only two wires comin out of the parkin lights i dont get how i could mess this up any ideas???????????????????????????
Old Oct 5, 2009 | 08:38 AM
rockinbboy's Avatar
rockinbboy
you getting a signal through the wires? Make sure you didn't accidentally cross wire. The electronic/wiring/tech subsection might be more useful, maybe you can move your post there (need a moderator to move the thread)
Old Oct 5, 2009 | 09:39 AM
james-z33's Avatar
james-z33
theres only two wires from the 370 emblem and two from the parkin light i connected them they workd for a min now they dont.... no fuses is blown... i unpluged the connection from the side marker an still no parkin lights
Old Oct 5, 2009 | 10:25 AM
zenki_z33's Avatar
zenki_z33
Well it really sounds to me like a fuse is blown due to wire crossing... Also why are you wiring them to your parking light? Shouldn't the markers be wired to the turn signals? I'm on my iPod right now, but when I get to a computer I will try linking a D.I.Y.
Old Oct 5, 2009 | 06:36 PM
eod nhoj's Avatar
eod nhoj
Default fuse box
there is a third fuse box located behind the battery, u will have to remove the cover for the battery and the covers that the battery cover attaches too to get to it, check the fuses in it. i know the fuse for the tail lights is located there not sure what else though.
Old Oct 6, 2009 | 08:08 AM
sam2944's Avatar
sam2944
I did the job. Just take a tester and see if you got dc in the wires. I did it few months ago and I dont remember, but probably they are LEDs in the interior and have polarity. May try swapping the wires. www.sagahid.com
Old Oct 19, 2009 | 05:36 PM
redzlove's Avatar
redzlove
i have actually done this swap and its easy...you just have to get the wires right at first...because it sounds like a fuse somewhere in 1 of 3 boxes...a fuse can only hold the crossed wire for so long before it blows...i connected mine to the turn signal on a quick disconnect so if i had to remove the headlight i could without an issue. it took me 2 hours to cut holes shim an mount them an as i said NO PROBLEMS at all...it has to be your wires! double check BOTH sets of wires because it is one complete circut!
Old Oct 21, 2009 | 02:51 PM
james-z33's Avatar
james-z33
everything was wired rite just didnt realize it had three fuse boxes....... alll good an golden they work
Vigman
Nov 17, 2015 04:34 AM
_koubie_
Sep 20, 2015 06:34 PM
