Headlight issue
Old Oct 6, 2009 | 09:16 AM
RussucoBlack350's Avatar
RussucoBlack350
Default Headlight issue
OK so a week ago I posted about a headlight that had gone out. I purchased some bulbs and tried swapping the bulb out. Still no light, i am going to get the car back in the air today and test the bulbs in the working headlights to make sure i bought the correct lights. If this shows that its not the light what else could be wrong with the headlight. Ballast? Also the inner housing of the headlight is cracked and broken, i think this is from when the d*** head who keyed my car pushed the key on the headlight.
Also in the inner fender there is a bolt where it connects the two finder walls together. Its along the top of the inner finder wall, is this one of those bolts that you have to squeeze to get out. I tried taking out the bolt that is on it but the whole bolt itself just spun.
Russuco
Old Oct 6, 2009 | 09:20 AM
ni$mo350's Avatar
ni$mo350
It could be aballast issue but not likely. What bulbs did you get?
Old Oct 6, 2009 | 01:02 PM
pbass6811's Avatar
pbass6811
If you have Xenon's, it's probably the ballast. I had a headlight go out, replaced the bulb, still no headlight. Replaced the ballast, Voila, headlight worked! In fact, the bulb that was in it still worked! Now it's gone out again, so I'm just gonna get a whole new headlight...
Old Oct 6, 2009 | 01:07 PM
ni$mo350's Avatar
ni$mo350
Instead of wasting money on a whole new HID kit an easy test is to just put a bulb you know is good into the broken headlight and if it lights up then it's a bulb issue not a ballast and if it doesn't light up then it probably is a ballast issue.
Old Oct 6, 2009 | 09:49 PM
pbass6811's Avatar
pbass6811
While I certainly agree that $600+ for a frickin' headlight seems a bit exhorbitant, I think that's pretty much what we all said...try the bulb in the working socket. If it doesn't come on, the bulb is done. If it does light up in the other socket, then it's the ballast. OP, we're assuming you have HIDs and not halogens....
In MY case, my drivers side headlight is full of rust and condensation and looks like @$$, so I want to replace it. I was thinking about replacing both headlights with '06 Bi-Xenon's, but there's a very real possibility that I'll trade this Z for a newer one anyway! Don't really wanna sink $12-1300 into headlights and then turn around and buy a car that's already got 'em...
Old Oct 7, 2009 | 08:21 AM
sam2944's Avatar
sam2944
I suggest start using a tester to confirm you got dc in the wirings. If yes, you got a defective ballasts. www.sagahid.com PM if need support.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
