Spoiler removal
Old Oct 15, 2003 | 12:52 PM
jedoublery's Avatar
jedoublery
Default Spoiler removal
I wanna get rid of the stock spoiler, never liked it, but it happens to be on the car that I wanted to buy.
I am just gonna be spoiler-less for the rest of my Z ownership
They are glued on or screwed on? Any suggestions on how to remove it?
If anyone wanna buy it? PM me. thanks (can I do this here?)
***Oh, it's Silverstone color, no scratches whatsoever, I only have 2000miles on the car***
Old Oct 15, 2003 | 01:09 PM
Z-INCOGNITO's Avatar
Z-INCOGNITO
Im sure they are screwed on... dunno how to self remove it, plus you'll have visible holes... maybe im wrong
Old Oct 15, 2003 | 01:18 PM
Randall Patters's Avatar
Randall Patters
Default stock spoiler
The stock spoiler is bolted on. if you pop the inside cover off you can see 4 holes!
Old Oct 15, 2003 | 04:09 PM
ragtopz's Avatar
ragtopz
yeah, if they installed it properly, then they bolted it on and taped it. i heard of some just being applied with tape. i guess you could check underneath to see if you can see the bolts. if so, and you want to go spoiler-less, then i guess you are going to have to do some bodywork to cover the holes.
good luck.
Old Oct 15, 2003 | 08:55 PM
crashx's Avatar
crashx
good luck.
Or just trade someone who has the same color hatches. Like me!!!
Old Oct 16, 2003 | 06:47 AM
Wedge's Avatar
Wedge
Another alternative is to go with an aftermarket spoler that you like better. Some of these are designed to use the existing holes from the stock spoiler.
Old Oct 16, 2003 | 07:39 AM
kbsig106's Avatar
kbsig106
Default Which ones?
Would the NISMO spolier fall into that group using the existing holes. I love the stock spoiler but I'm looking for something MORE!!!!!
Thanks in advance
Old Oct 17, 2003 | 07:31 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Default Re: Which ones?
The Nismo spoiler will require 4 more holes to be drilled and you will still have some 1/2 holes left under it from the old spoiler. you just need to silicone or tape over(or both) the old holes. We have also had to send out 3 cars to have their trunk lid repainted as the stock spoiler lifted the paint it was glued (taped)on so well. Still I feel it's worth all the trouble as I personally like the look of Nismo and aftermarket spoilers on our cars.
Old Oct 18, 2003 | 06:10 PM
silver&black03's Avatar
silver&black03
remove the inside panel. remove 2 10mm nuts, there are also 2 pop clips, and lots or 3m tape. use plastic weed wacker cable to cut through the 3m tape in a sawing motion. then use silicone spray. spray and let soak to remove 3m backing. this wont harm the finish.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
