How can I remove the center console cubby lid?
Old Dec 16, 2009 | 11:37 AM
nlauri's Avatar
nlauri
Default How can I remove the center console cubby lid?
I searched but couldn't find any help to remove the big lid off my center console cubby so I can send it in to have it covered in leather. I have a 03'. Any help would be appreciated...afraid to break the thing.....Thanks
Old Dec 16, 2009 | 11:39 AM
JasonZ-YA's Avatar
JasonZ-YA
start here:
http://liljerk.morpheus.net/350Z/dash_removal/
then from there you can remove it from the inside iirc.....eehh.
is it the 03 non motorized??
-J
Old Dec 16, 2009 | 11:42 AM
nlauri's Avatar
nlauri
Sorry I should have been more specific...the cubby back off the side of the drivers seat is the one I want to take the lid off. The storage compartment with the big lid with the cup holders inside. Thanks
Old Dec 16, 2009 | 01:11 PM
JasonZ-YA's Avatar
JasonZ-YA
okay, then you need to follow that link still and remove only the part around the shifter....then from there pull up the coin tray.....then push seats all the way forward, there are screws in that center section behind the seats and then from there i believe you just pull it all out..
-J
Old Dec 16, 2009 | 09:00 PM
lbz's Avatar
lbz
There are two screws in the very front of the center console that have to be removed as well as a couple of small "L" brackets.
In order to get the shifter finisher off, you will have to remove the shift ****, then pull up and back from under the rear edge of the lower finisher trim ring to pop off the finisher and lift it up and over the shifter.
Depending on the model year, you will have to disconnect the hazard light switch from either the lower finisher or the center console. Best practice on removing manual transmission shift **** is to use two pairs of pliers. One to hold the shifter steady and the other to turn the ****. Putting too much torque on the shifter can cause damage.
You can use rubber hose to protect both the shifter and the base of the **** or wrap both in several layers of electrical tape. Use medium size channel locks or vice grips.
Pull the E-Brake handle up as far as you can in order to get the console up over it.
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
