Cusco door bar on a Autopower cage?
You should look into them. I think they are a lot better idea than the adjustable clamp-on bar.
Here is a PDF of all the additional bars
http://www.cusco.co.jp/en/pdf/Roll%20cage_option.pdf
"Bolt On Additional Bar" I believe is the adjustable ones. They have carbon, aluminum, or steel.
"Side Bar Kit" is I think what you would find suits you best. If I'm not mistaken, that's the one with no joint that you cut/bend to your desired position and then weld the tabs on. Safety21 is probably the one you would want to choose (over the Cusco ones).
Dash escape bars are present once again. The doors bars are way too high for my tastes probably making it a PITA for anyone to get in and out of. I would rather see some sort of uninterrupted door bars with dimple plates or at the very minimum a X-brace.
