Have already searched and read all the how to's, but still having trouble programming the mirror, able to power it on and off, I have 2 garage remotes i tried to program nothing, (no rolling codes, one liftmaster and one genie) also tried to reset it nothing. Theres a green light on, but cant get it to blink according the the programming instructions. Only buttons that seem to work are the on and off button.
You didn't mention if you are sending the signal from the opener. You do this by going to the opener (motor) and pressing the button that sends a short 60 sec burst with your "signal". The Homelink will "catch" this signal and pair the two. It took me a few times, but worked easy.
yes, have the original remotes, no button on the the actual garage door motor itself, i was told the mirror came off a 03-05 z, has 3 wires going into the mirror.
i also read i could reset the mirror by holding down 2 buttons i believe it was #1 and #3 garage buttons for 20 seconds and it should blink, but that didnt work either.
I there is not learn lever to push then open the light cover, is there, you just have to find it.
then obviously you have a defective mirror or installed it incorrectly
