Sparco Harness Bar - G35
Old Jan 19, 2010 | 05:33 AM
RandomHer0's Avatar
RandomHer0
Default Sparco Harness Bar - G35
I'm trying to figure out if the 350Z Sparco Harness Bar will also work in the G35. Does it have the same mounting points?
Can any vendors confirm this?
I asked for help in g35driver but really unless you're asking about pretty wheels or a "sick drop" they don't have the info my350z does.
Thanks for any input.
Old Feb 24, 2013 | 11:35 PM
jining's Avatar
jining
did you ever figure this out?
Old Feb 24, 2013 | 11:44 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Is it for show or track use?
If it's for track use have something fabbed up...may be cheaper and less painful than making something not meant to work!
Keep us posted
Old Feb 24, 2013 | 11:47 PM
jining's Avatar
jining
Its for track primarily so functionality is key. Looking at the sparco bar it seems like it could work, pretty simple design, but I don't want to pay $400-500 to find out... I'll look further into having something fabbed. Thanks for the suggestion.
Old Feb 26, 2013 | 03:18 PM
jining's Avatar
jining
So here is a picture of my g35 coupe B pillar, could someone with a 350z tell me if this looks like yours, or maybe snap a picture for me so I can compare? I contacted Sparco and they said the 350z harness bar won't work in a g35, but who knows if they have tested it, or if they are saying that for liability reasons.
Old Feb 26, 2013 | 03:24 PM
terrasmak's Avatar
Probably the lower mounting points are different.
Old Feb 26, 2013 | 03:27 PM
jining's Avatar
jining
Ah... yea thats probably true, I didn't realize how it mounted to the rear, I see it now
Old Feb 26, 2013 | 03:38 PM
jining's Avatar
jining
Hmm I am confused, when I google sparco harness bar for the 350z, it shows a bar with 2 arms that extend downwards off the bar to lower mounting points. Maybe that is a stock photo used for all harness bars, because I see this one:
https://my350z.com/forum/attachments...n-imgp3866.jpg
and it doesnt use any arms, it just has a bracket against the b pillar that prevents the bar from rotating.
The picture was from this thread: https://my350z.com/forum/body-interi...tallation.html
Old Nov 5, 2013 | 04:18 PM
joeb1983's Avatar
joeb1983
Old thread I know, but if anyone is searching here is what I came across in my quest:
I have talked to several vendors and most say that Sparco does not list it for the G35, so it will not fit... So, I called Sparco USA and was told it was solely designed and tested for the 350z and it has not been tested in the G35 so they do not recommend you try and use it.
I also spoke with Speedware-Motorsports in Washington as they manufacture the bars for Sparco and they told me that the interior panels on the G35 are different and it will not work.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
