Hid bulb
Old Jan 25, 2010 | 06:47 PM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
Default Hid bulb
Hey guys,
Due to the recent rains, my headlights had some condensation, causing the bulb to go out. I took it out to dry today, and noticed the middle of the hid bulb, where the gas burns, is dotted with brown dots/has condensation. I don't know if its going to work after I install it, but in case it doesnt work, I wanted to ask a few questions. If I install everything back together, and the main bulb does not turn on, is it because there is water in the bulb itself? Or because the ballast is messed up. Also, If I get new hid bulbs for my 08z, what is the highest temp I can go before it is illegal/too blue. Thanks.
Old Jan 25, 2010 | 06:56 PM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
also, this may be a really stupid question, but are the high beams produced from a bulb separate from the regular headlight bulb? When I opened up my headlights, I could only see the main hid bulb, the turn bulb, and city light bulb. Couldnt find the high beam bulb. Thanks.
Old Apr 7, 2010 | 08:09 PM
dbrown's Avatar
dbrown
i am having the same problem i would just use a test light and check the ballast connection to the bulb and check the wires going to the ballast....
Old Apr 8, 2010 | 05:50 AM
Thermal1's Avatar
Thermal1
08s have bi-xenon headlights. Both the hi and lo beam are in 1 bulb. A metal sheild moves to output more light or something like that.
I think any color change from stock is probably "illegal" but you won't get pulled over for something in the mostly white range. I have 6000K bulbs. Very white with just a hint of blue.
Edit: Well, I just noticed this is a few months old... OP, you got any updates?
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
hardwood66
Sep 8, 2015 04:31 AM
Mr Fairlady
Jan 28, 2003 06:08 PM
dvlad
Sep 15, 2002 07:48 PM
