Is there a DIY on switching 03-05 headlights to 06-08??
Old Mar 6, 2010 | 07:35 PM
SnyzzleZ's Avatar
SnyzzleZ
Default Is there a DIY on switching 03-05 headlights to 06-08??
ive been searching for this for the last hour and couldnt find it.. I know there has to be one out there already..
update: did the install today and it went pretty smooth.. the only problem i had was with the bumper clips.. i broke 2 of them.. does anyone know where i can get replacements??
will post some pics tmrw.
Old Mar 6, 2010 | 07:45 PM
johnwigs's Avatar
johnwigs
plugs right in as far as I know... I know tail lights for sure... headlights. seen one person swap headlights, so I know it can be done
Old Mar 6, 2010 | 08:15 PM
SnyzzleZ's Avatar
SnyzzleZ
hopefully thats the case.. i thought there was a small modification that needed to be done but maybe im wrong? can anyone confirm this?
Old Mar 6, 2010 | 08:20 PM
surfcity40's Avatar
surfcity40
which headlights are you wanting to switch?
surfcity40's Avatar
surfcity40
did you mean tails?
Old Mar 6, 2010 | 08:30 PM
tware's Avatar
tware
the best way to handle this is to get the plugs from the 06+ lights. You WILL have to splice your wires into the new plugs. Have a volt meter handy and test/mark the functionality of each wire, the color codes are not the same.
It's actually a VERY easy job if you have enough wire from the new connectors. The thing is, they are headlights. You really dont want them going out on you. You dont want corrosion or shorting, so take your time. Solder them properly (X them together so they cant be pulled or shaken apart). Use thick/quality shrink tubing and make sure to zip tie the harness in place so vibration cant do any damage to your connections. Seal it all up as best you can. And then enjoy some seriously bada$$ lights.
Old Mar 6, 2010 | 08:57 PM
SnyzzleZ's Avatar
SnyzzleZ
Well right now i have the oem 03 hid headlights so will it still require the wire mod? I don't have a solder gun and don't wanna f it up obviously
Old Mar 6, 2010 | 09:16 PM
Waiz's Avatar
Waiz
https://my350z.com/forum/exterior-an...rect-swap.html
https://my350z.com/forum/exterior-an...ssue-help.html
https://my350z.com/forum/exterior-an...ease-help.html
These should help you out...
Old Mar 6, 2010 | 09:17 PM
ppwpz33's Avatar
ppwpz33
No need to worry. Since you already have OEM HID assemblies it is plug and play. Tails as well. IF you have the base like me you will have to do some wire clamping or splicing like I did which is still not too bad once you have the right diagram.
Old Mar 6, 2010 | 11:29 PM
nismo1234's Avatar
nismo1234
Default Healight swap
i have an 04 350z base when i did my conversion i got my harness off an 05 enthusiast model and cut off the old harness and put the new harness on it was all color coded so no wories about that i used the wires and allot of electrical tape. anyway You wouldent need to go through all of this because you have factory HID which would be a direct swap no modification required. weather you have a base w/o hid or w/hid both ways are very easy to do.
Old Mar 6, 2010 | 11:34 PM
LaoSiFu's Avatar
LaoSiFu
https://my350z.com/forum/body-interi...k-housing.html
Here is my DIY on removing the bumper and headlights. It is all plug and play and you should not have any difficulty.
~Robert
Old Mar 7, 2010 | 01:50 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Did you find another set? How'd everything go with the scammer?
Old Mar 7, 2010 | 03:34 AM
Z04's Avatar
Z04
no, the lights will plug right up. i have them on my '04 and no issues at all. you only have to do the wire mod if you have the base halogen lights and want to convert to the HID. you will have to modify the turn signal bulb though. i can't remember what bulb to snip
Old Mar 7, 2010 | 06:56 AM
SnyzzleZ's Avatar
SnyzzleZ
yea i found another set.. just got a notification from paypal yesterday they are refunding my account within the next couple days.
Old Mar 7, 2010 | 06:57 AM
SnyzzleZ's Avatar
SnyzzleZ
thanks for the help
Old Mar 7, 2010 | 07:01 AM
SnyzzleZ's Avatar
SnyzzleZ
~Robert
should be very helpful.. about how long did it take to get the bumper and lights out?
Old Mar 7, 2010 | 09:44 AM
LaoSiFu's Avatar
LaoSiFu
Well in my case it is pretty quick because I done so many headlights which is about 10 minutes (making sure I have all the bolts and clips). I would say if you have never done it perhaps 15-20 minutes. If you get suck feel free to message me.
~Robert
Old Mar 7, 2010 | 12:20 PM
SnyzzleZ's Avatar
SnyzzleZ
wow... actually thought the bumper was goin to be a pita.. plan on switchin them in about a week or 2 so ill let you know if i run into any problems. so thanks ahead of time lol
Old Mar 18, 2010 | 06:07 PM
SnyzzleZ's Avatar
SnyzzleZ
just did the install using some of the links u guys provided which definately helped. i did however break 2 of the bumper clips on top.. anyone know where i can get replacements?
Old Mar 19, 2010 | 05:17 PM
sluggoZ's Avatar
sluggoZ
At the dealership, appox. 90 cents each.
There's a trick on bumper clips removal....works like a charm!
https://my350z.com/forum/exterior-and-interior/157122-damn-plastic-screws-holding-the-front-bumper.html
