05 Cubby Door Springs
Old Mar 8, 2010 | 08:27 AM
Candy_man's Avatar
Candy_man
Default 05 Cubby Door Springs
Can anyone explain how the springs in the cubby door are supposed to be installed? I took the door off a while back and now I can't figure it out. There's a gold and a black spring that make the door pop when it's unlatched - they both have a long and short side. Any tips, diagrams, pictures would be great. I did a search but did not find anything.
Thanks!
Old Mar 8, 2010 | 11:57 AM
zzzcoupe's Avatar
zzzcoupe
yes these are a pain the circle part goes around the piece where the screw goes, one end goes into a little clip on the door i believe and you have to wind the spring a little so it will push the door open and then set the long side into place against cubby i believe hope this helps
Old Mar 8, 2010 | 12:20 PM
Candy_man's Avatar
Candy_man
Thanks zzzcoupe - I'll give that a shot. Do you know which spring goes on which side (gold/black & passenger/driver)?
Also, if anyone has a pic of the springs installed, I'd appreciate it.
Old Mar 8, 2010 | 12:55 PM
beezee's Avatar
beezee
Hope this helps you . It is an 05 cubby.
Old Mar 8, 2010 | 01:00 PM
Candy_man's Avatar
Candy_man
Awesome - thanks so much.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
