Swaping 06+ headlight for 04
Old Mar 9, 2010 | 08:03 PM
LD7's Avatar
LD7
Default Swaping 06+ headlight for 04
Recently i have swaped my 04 HID headlight to 06+, everything works fine, but there is a problem, when i turn on the light, the turning signal bulb always stay on, instead of the 3 little LED light at the corner which look on a 06+, i have seared the forum and know there is so mod to fix this, but i can not find any picture of the DIY, so anyone can help?
Thanks.
Old Mar 9, 2010 | 09:14 PM
Unique_Z33's Avatar
Unique_Z33
Grammar owns you my friend.
The turning signal is always blinking on or is solid on?
Old Mar 9, 2010 | 09:55 PM
LD7's Avatar
LD7
Is solid on.
Old Mar 10, 2010 | 01:29 AM
Z04's Avatar
Z04
you have to modify the wire on the bulb itself. when i did mine i had to just clip two of the 4 wires that are on the bulb. that way it only comes on with the blinker.
Old Mar 10, 2010 | 04:08 PM
LD7's Avatar
LD7
which 2 exactly? pictures would be helpful.
Old Mar 10, 2010 | 08:04 PM
JEKL's Avatar
JEKL
Try this...
https://my350z.com/forum/7646427-post10.html
Old Mar 11, 2010 | 01:54 AM
Z04's Avatar
Z04
^^ that would work but the way i am describing doesn't involve cutting any wires on the harness at all. that way if you want to revert your lights back to the originals you do not have to replace that wire. i just forgot which two wires to clip on the bulb itself and it is a PITA to go out and just pull one of mine to see.
Justin100
Nov 25, 2021 06:26 AM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
Viethoang91
North East Marketplace
Sep 21, 2015 01:16 PM
