Personal + Nardi + Redline Goods + WB QRS
Old Mar 9, 2010 | 11:11 PM
ctwentytwo's Avatar
ctwentytwo
Default Personal + Nardi + Redline Goods + WB QRS
OK, finally got home from vacation and put everything I've been piecing together for about a month...
Personal Neo Grinta 330mm Steering wheel
Nardi e-brake handle
Redline Goods shift and e-brake boot (Black leather/silver stitch)
Works Bell QRS and short boss
Special thanks to Synth19 for putting this in my head... my wallet is now AWOL 'till next year.
Some notes:
* A 330mm steering wheel IMO feels awesome. All my cars will now have a 330mm wheel or smaller.
* Short Boss + QRS actually lessens a little distance of the steering wheel to driver. If you're looking for even less distance, go with a flat steering wheel; ie: Neo Eagle is flat vs Semi-deep Neo Grinta
* Getting that Nardi handle on is a biatch
* Redline Goods quality is AWESOME!
Man I'm tired...
Old Mar 9, 2010 | 11:13 PM
gregtotheb's Avatar
gregtotheb
looks awesome! whats next?
Old Mar 9, 2010 | 11:27 PM
nismo_nate's Avatar
nismo_nate
nice work
i was wondering, on the ebrake handle... did you have to slice the rubber off or does the nardi ebake just covers the lever? also the cost of the nardi piece please.
i know the momo ebrake goes for $80ish. but that nardi piece looks so much better. you can also pm me the price
thanks
Old Mar 10, 2010 | 01:27 AM
duro78's Avatar
duro78
Well worth the money looks really good. ^+1 on the e brake install how difficult was it getting the stock one off. By the looks of it thats not a quick release hub correct?
Old Mar 10, 2010 | 05:29 AM
lgear080's Avatar
lgear080
awesome parts and outcome. surely makes driving more fun too.
Old Mar 10, 2010 | 05:57 AM
Brrcats's Avatar
Brrcats
in b4 head on collision death
jk brah, looks real good
Old Mar 10, 2010 | 10:27 AM
ctwentytwo's Avatar
ctwentytwo
... saving.
Seriously, I want to wrap some pieces in di-noc... also will probably go for some "go" mods with hfc's and sway bars.
Originally Posted by nismo_nate
nice work
thanks
Yes, you need to remove the leather or polyurethane off the handle otherwise it won't fit. Don't "cut" it, but just run a thin putty knife down one of the two seams. You want to just separate one of the seams.
***Warning*** The Nardi handle will slide in about 3/4's of the way, but you will need to shave down the e-brake on the car with a file in some places to get it to slide all the way in. Also, the piece is all aluminum, and will take time to cut the handle with a dremel. If you aren't skilled with tools, don't do it.
Google "Crowder's Customizing." It ran about $80.
It is a quick release. It's a Works Bell QRS, thinner than the Works Bell Rapfix II. Chose it so that the wheel would kept in more of a stock position.
Getting the stock e-brake off is easy, again, don't cut it, but just use a blunt tool to run down one of the seams. The leather/poly and the front plastic piece under the handle are held by "star washers" though. Just give a tug after you split the cover.
*** Or you can take off the center console if you want to "save" everything... and you can see what I'm talking about. To take off the center console, take off the shift boot cover like when you want to change your shift ****- it will expose 2 screws that holds the front portion of the center console on. Remove the ashtray, there's a screw beneath it. Then remove screws on both side of the center console near the rear- recline your seat forward and you should see them. Remove the plug to the hazard button and your'e set.
I recommend doing it this way as it'll let you take the rubber surround around the handle off properly. If you try to take it off from the outside like I did, you make tear off a tab... like I did. Also, it is a PITA to take that off from the outside. Reason why you want to take that rubber surround off is so you can tuck the leather boot in properly, otherwise, it may bunch up like some of the examples you may have seen.
Good luck.
Hell yeah. Drove indoor kart while in Arizona and kinda gives it that type feel, but with power steering... LOVE THE SMALLER FEEL.
If I suddenly stop posting here, I'll be haunting you and reminding your that you "bachi'd" me.
Seriously, that does come into mind, but it's the chance I'm gonna take. I'm thinking of buying a helmet though.
Old Mar 10, 2010 | 11:30 AM
jkocr2's Avatar
jkocr2
when you ordered the shift boot did you order it shorter than stock? if so how much? yours sits perfect.
Old Mar 10, 2010 | 11:34 AM
ctwentytwo's Avatar
ctwentytwo
The shift boot is stock sized, and compared to the stock boot, is exactly the same size. Even has the mounting holes stamp in them so installation is a snap.
The shorter boots are made for short shifters, unless you want the look of a more taught boot.
Old Mar 10, 2010 | 12:18 PM
finalforce's Avatar
finalforce
Interior is looking good man.
Old Mar 10, 2010 | 01:54 PM
duro78's Avatar
duro78
Thanks for the in depth instructions will be doing this shortly thanks bro
Old Mar 10, 2010 | 03:37 PM
SnyzzleZ's Avatar
SnyzzleZ
that ebrake looks baller. might have to go with with that same one.. where did you buy yours from?
Old Mar 10, 2010 | 08:51 PM
nismo_nate's Avatar
nismo_nate
Post a diy please.. I'm thinking of doing the ebrake mod soon since I'm customizing my interior with suede+cf fabric.
Is the diy like the momo ebrake diy?
Old Mar 10, 2010 | 10:59 PM
ctwentytwo's Avatar
ctwentytwo
Just updated the horrible pics from yesterday.
Thanks.
Lets see what you come up with.
Crowder's customizing (like I wrote above to answer the same question... but the Nardi is not quite as baller as this by Isotta:
Yes, just like the Momo. Just make sure that when you get the handle you want... the inner diameter of the hole is at least 1 inch. When you get your handle, you'll know what adjustments to do to the Momo DIY.
But again, like I stated above... you will have to shave the handle on the car down a little with a file.
Old Mar 11, 2010 | 03:50 AM
SnyzzleZ's Avatar
SnyzzleZ
hah your right maybe ill go with that one instead
Old Mar 11, 2010 | 04:58 AM
Highway Riding's Avatar
Highway Riding
everything looks really nice and clean. +1 I'm considering a personal steering wheel myself.
Old Mar 11, 2010 | 06:04 AM
Z350Maniac's Avatar
Z350Maniac
That Ebrake handle REALLY makes it all come together. Thanks for the how-to and the purchasing info =D
Old Mar 11, 2010 | 08:21 AM
uglyduc's Avatar
uglyduc
Zexy bits, well done.
Old Mar 11, 2010 | 10:21 PM
MethodRN's Avatar
MethodRN
For Sale
Looks great! really like that QRS system.....
Old Jun 28, 2013 | 07:49 AM
nismo4life11's Avatar
nismo4life11
Bringing this tread back from the dead since its one of the only ones that came up when I looked for this QR. I'm looking at doing a WB QRS, regular boss hub and a Nardi 330mm Deep corn. Does anyone know what the measurements are for this setup vs stock? Im trying to get something close to stock.
apex locator
Jul 23, 2021 02:27 AM
