looking for DIY guide for harness install
Old Apr 7, 2010 | 05:17 PM
ginobetterfly's Avatar
ginobetterfly
Default looking for DIY guide for harness install
http://www.sparcousa.com/pharness_comp.asp?id=577
i just picked up these harnesses and sparco harness bar...
I searched and found a DIY guide to install the bar, but cant find anything on how to attach/wrap/install the belts, for specifically the 350z application... can someone point me in the right direction?
Old Apr 12, 2010 | 05:58 PM
ginobetterfly
come on, i know lots of people here are running harnesses with a bar... no one can help?!
Old Apr 13, 2010 | 07:09 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Here ya go, homie:
First, the bottom two mounting points are
(1) The bottom stock seat belt mounting bolt (below driver door where seatbelt bolts) is where you bolt one side of the harness.
(2) The right rear stock seat bolt on driver's right hand side (next to center console area...you may need to buy a longer bolt to hold both the seat and harness bracket down, and you may need to make/buy an 'L' bracket and connect harness to one side and seat bolt to other side)
Note: You are actually "supposed" to drill a hole in the trans tunnel and weld in a support plate, then attach an "eye" bolt in from inside, then secure harness to that (pictured below) I just bypassed all that noise and installed an 'L' bracket to connect harness to rear seat bolt.
And this is how you loop the top 2 ends of the harness to the bar:
Old Apr 14, 2010 | 10:23 AM
ginobetterfly
^thanks for your help man!!
HoBrahYouStink
Jun 24, 2016 10:58 PM
