window malfunction?
Old May 17, 2010 | 05:16 PM
1BADZ33's Avatar
1BADZ33
Default window malfunction?
When I roll up the automatic window on the passenger side it goes all the way up then goes back down about 1/4 of the way. Is this normal? Or is there a fix for this? The driver side window is just fine.
Old May 17, 2010 | 05:32 PM
Lee R's Avatar
Lee R
https://my350z.com/forum/search.php?searchid=11461310
Old May 17, 2010 | 06:16 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Very common, replace window motor is fix.
Old May 17, 2010 | 06:37 PM
FineWine's Avatar
FineWine
Actually, sounds like the motor works, but needs to be reset.
Search.
this has been covered already and there is a DIY in the DIY section.
Old May 17, 2010 | 07:36 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Sounds to me like the motor is starting to go if the window is sagging on its own. That seems to be the most common circumstance when involving this problem.
But yes, try the reset first...its free.
Old May 18, 2010 | 03:18 PM
1BADZ33's Avatar
1BADZ33
I'll try that guys. Thanks.
Old May 18, 2010 | 07:31 PM
mariar508's Avatar
mariar508
I've already replaced my passenger side motor. Now the drivers side is going out.... It's a losing battle. Just have to accept the fact that nissan window motors suck.
Old May 19, 2010 | 05:42 AM
FineWine's Avatar
FineWine
Try cleaning it first. Just make sure you get all of the electronic cleaner out of it before you plug it back in (the mistake I made).
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
AP350z223
Sep 8, 2015 04:38 PM
