McGuires Plastic X...really works !
Old Aug 17, 2010 | 05:03 AM
jamesdean's Avatar
jamesdean
Default Meguiars Plastic X...really works !
Just did the driver side headlight with this stuff then buffed with a lil wax...They almost look brand new aside from a few stone chips that were too deep to remove. I was starting to get mild clouding around the edges and it was bugging me so thought I would give this a try. Worked great. I will get some pics of the passenger side since its not done and the driver side for comparison here in a few mins
Before:
After :
Old Aug 17, 2010 | 05:06 AM
omsin523's Avatar
omsin523
yeah, it works pretty good. You spelled it wrong though.
Old Aug 17, 2010 | 05:18 AM
jamesdean's Avatar
jamesdean
Lol so shoot me
Old Aug 17, 2010 | 05:24 AM
jamesdean's Avatar
jamesdean
Btw that headlight took about 5 mins to do
Old Aug 17, 2010 | 05:56 AM
Results look great. You did the buffing by hand?
Old Aug 17, 2010 | 05:57 AM
sofa king's Avatar
sofa king
good result.
Old Aug 17, 2010 | 06:06 AM
Entaille's Avatar
Entaille
I had similar results. month later the headlights looked like **** again
Old Aug 17, 2010 | 06:21 AM
jamesdean's Avatar
jamesdean
Used the buff wheel that came with the kit. I figured it would not last but as simple and fast as it is to do I can just redo it as needed. Car sits out in the sun 8+ hours a day when at work
Old Aug 17, 2010 | 07:06 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Lmao... whats the coffee cup for? I use the 2 step marine polish but its hard to come by now a day. Sweet work. One question... did you use Cotton, Foam, or Micro fiber application methods?
Old Aug 17, 2010 | 07:19 AM
phreaktor's Avatar
phreaktor
Design Engineer
I used a mothers Powerball and was much less than impressed...
Old Aug 17, 2010 | 07:55 AM
abo's Avatar
abo
wow. you sold me. i'm going after work to pick this up. thanks for the post. nice work.
Old Aug 17, 2010 | 07:59 AM
VQ35deMax's Avatar
VQ35deMax
It does work but the results are not permanent. Best way to achieve a permanent result is to sand the headlights and then clear them. I do a couple of sets of headlights everyday at the body shop I work for.
Old Aug 17, 2010 | 08:02 AM
jamesdean's Avatar
jamesdean
Used the wheel that comes with the kit in a cordless drill on medium speed. The coffee mug jsut happened to be sitting there lol didnt stage the photo
Spent less than 5 mins a side on them then used some meguiars wax after I was done. 15 minute project so if I have to redo in the future its a pretty simple deal. If the car were newer I would probably try and find something to keep it from happening again but its a 04 w/ 50k so its not spotless anyway
Old Aug 17, 2010 | 08:05 AM
jamesdean's Avatar
jamesdean
I thought about doing that but I haven't done that type of thing since shortly after HS and I am to afraid of screwing up my lenses. What do you use like a 800 grit wet or ?
Old Aug 17, 2010 | 08:07 AM
Toby-22's Avatar
Toby-22
i did this when i had my 03-05 headlights, worked great!
Old Aug 17, 2010 | 08:29 AM
dmroberson's Avatar
dmroberson
+1. The Mothers Powerball is full of FAIL.
Old Aug 17, 2010 | 08:40 AM
VQ35deMax's Avatar
VQ35deMax
Depends on how bad the headights are. But usually I wet-sand them with 600 or 800 and then go over with 1200 grit. However I would not suggest using the clear coat that they sell in a rattle can.
Old Aug 17, 2010 | 09:03 AM
angelo350z's Avatar
angelo350z
I used 2000 grit sandpaper with 3M rubbing compound on my Integra and Eclipse years ago. They looked brand new afterwards.
Old Aug 18, 2010 | 11:18 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
looks good, great job!
Old Aug 18, 2010 | 12:05 PM
97supratt's Avatar
97supratt
Looks good, now keep it up every few months and it should keep it's luster for a long time.
