"PREDATOR" Design 350z led tail lights
Old Aug 25, 2010 | 07:37 AM
1 MEAN Z's Avatar
1 MEAN Z
Default "PREDATOR" custom 350z led tail lights
First off I am not selling these tails here on my350z.com just showing them off. I just finished building these tail lights, let me know what you think of the design.
All of the 5mm leds have been changed to10mm. These tail lights house turn signals and reverse lights.
For more pics and videos go to:
MyLightEmittingDesigns.weebly.com
Thanks for looking...
http://www.youtube.com/watch?v=Ey5vju6WSUI
Old Aug 25, 2010 | 07:42 AM
RandomHer0's Avatar
RandomHer0
hehe, I think its pretty neat.
Old Aug 25, 2010 | 08:29 AM
vex008's Avatar
vex008
I like that a lot.
Good stuff
Old Aug 25, 2010 | 08:53 AM
definitionxmk's Avatar
definitionxmk
Good stuff
Old Aug 25, 2010 | 09:00 AM
laxplaya1385's Avatar
laxplaya1385
that looks awesome! very creative.
Old Aug 25, 2010 | 12:16 PM
1 MEAN Z's Avatar
1 MEAN Z
Originally Posted by vex008
I like that a lot.
Good stuff
Originally Posted by definitionxmk
Good stuff
Thank you!
Old Aug 25, 2010 | 12:26 PM
vex008's Avatar
vex008
had a bit of a slow moment there. watched the vid for the second time and
just realize the reason for the name "predator".
Old Aug 25, 2010 | 02:16 PM
1 MEAN Z's Avatar
1 MEAN Z
Yeah, lol, once I was done building this design and started to look at it when the running lights and brake lights are on, that was the first thing that came to mind. The targeting system on the predator helmet...Funny, but it works...
Same with the last design, that I am now calling "Evil Z". They remind me of this....
Old Aug 25, 2010 | 02:27 PM
surfer05rdr's Avatar
surfer05rdr
did you design the light to simply plug into the oem harness or do you have to modify the harness for the turn signals and reverse lights to work
Old Aug 25, 2010 | 02:41 PM
1 MEAN Z's Avatar
1 MEAN Z
I have checked with Nissan on getting all of the plugs. They do not sell the plugs for the tail lights or OEM turn/reverse lights seperate, they are attached to the OEM lights and harnesses. The reverse/turn signal option does require a little modification to the harness in your Z. It is fairly simple; you would only have to tap in to the two wires leading to your stock reverse light, one being positive and the other negative. These are easily accessible once you remove your tail lights. The turn signals are fairly easy to tie into. This harness is also easily accessible, it is in the same location as your reverse light harness as they are located in the same housing.Your first option would be to tie in and leave your existing turn signals hooked up along with the custom turn signals.Your second option is to cut the two wires going to your existing turn signal in turn deleting them, then run the two wires you cut to the turn signal harness off the back of your custom tails.These custom tails come with new harnesses one end pre-wired to the tail lights and the other end will have to be wired in to your existing harness.
Old Aug 25, 2010 | 03:27 PM
surfer05rdr
Sounds great man I think the best option would be to use the oem turnsignal an the led one wish I knew how to do stuff like this I once tried to open an spare taillight I had an I did not work out at all lol
Old Aug 25, 2010 | 06:17 PM
can'tZme's Avatar
can'tZme
Looks cool OP
Old Aug 25, 2010 | 06:26 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
awesome tail lights! can't wait to see them on the Z!
Old Aug 25, 2010 | 10:09 PM
Shawz1102's Avatar
Shawz1102
I like it, needs to be hooked up the car!
By the way, what power source are you hooking up the tail lights to?
Old Aug 26, 2010 | 04:26 AM
Cossack's Avatar
Cossack
i woulds like to see the circuit design
Old Aug 26, 2010 | 12:38 PM
1 MEAN Z's Avatar
1 MEAN Z
I have a test box that I built with a flasher built in for the turnsignal operation. The box is powered by a 12v battery.
Hope that's what you wanted to know. If not let me know...
Old Aug 26, 2010 | 01:02 PM
vex008's Avatar
vex008
I was thinking the same thing.
1meanz,
you going to have to check the junk yard for a 350 rear clip, rest it in your backyard or garage, gut it and set it up for easy swap in and outs of all your different tails.
Know you going to get a lot of request for pics/vids on a car.
Old Aug 26, 2010 | 01:08 PM
CRIDDA's Avatar
CRIDDA
Old Aug 26, 2010 | 01:12 PM
1 MEAN Z's Avatar
1 MEAN Z
I'm in the business of making custom automotive led lighting for people. So I probably won't be posting any pics of my circuit designs. Every item shipped from My L.E.D. is designed and manufactured by me. I would be happy to answer any questions you may have about them if you would like.
Let me know....
Old Aug 26, 2010 | 01:30 PM
1 MEAN Z's Avatar
1 MEAN Z
1meanz,
Yeah, I hear ya....I can understand wanting to see them in the Z. Give me a little time to figure something out. Maybe this weekend if I get some free time, I will go and install one of the tails from each design so far in the rear if my Z and get some pics and video. I was thinking about swapping the design I have in there now for the Predator design anyways...
I will keep you updated....
