removing front nissan emblem
Old Sep 12, 2010 | 08:28 AM
TheBlue350z's Avatar
TheBlue350z
Default removing front nissan emblem
im looking to remove the front nissan emblem and black it out. ive seen many people do this on the forums, but was wondering if there is a diy thread on it.
what kind of paint did u use and how did u go about removing it?
Old Sep 12, 2010 | 09:23 AM
ASW's Avatar
ASW
can't tell you anthing about blacking it out, but i just replaced both the front and rear emblems (long story). anyway, the front is held on by double backed tape, thats it. no holes, pins, nothing. you'll just have to get something under it to pry it off. i was able to grab mine with my fingers and pull it off.
Old Sep 12, 2010 | 08:53 PM
Z_enthusiast's Avatar
Z_enthusiast
i got a lil pocket screwdriver,flat head, and pried mine off then use a rubber eraser wheel and adhesive cleaner to remove the excess tape. i would just use some krylon glosss black or matte. whatever u like. sand it with like 600grit or so before spaying. any rattle can paint would be ok for a emblem just practice getting your gloss right on somthing before spraying emblem.
Old Sep 12, 2010 | 09:22 PM
zaperroni's Avatar
zaperroni
1)Take a heat gun and hold it over emblem for .5-1 minute, until the glue softens up.
2)Pull off emblem with fingers, or carefully with screwdriver.
3)Remove excess glue with glu gone, or similar product.
4)Paint Emblem, (do multiple coats of clear coat so the paint doesn't chip.)
5)Put emblem back on car with 3m automotive grade adhesive.
This is the paint i used, no sanding required.
Old Sep 13, 2010 | 02:06 PM
TheBlue350z
thxs alot for the info guys.. i am prolly going to do the back nissan emblem as well. do u remove it the same way as the front?
Old Sep 13, 2010 | 05:04 PM
zaperroni's Avatar
zaperroni
Similar, but instead of using a screwdriver, take fishing line or floss to get behind the emblem.
Old Sep 14, 2010 | 03:47 PM
Z_enthusiast
It says no sanding required but as a body tech at a Chevy collision shop i would NEVER spay over a unsanded surface. why not just run some 600-800 over it? cant go wrong with reassurance.
Old Sep 14, 2010 | 03:50 PM
derekinthez's Avatar
derekinthez
Yeah, this is how I removed my emblems, worked like a charm (no chance of scratching the paint, like when using a screw driver).
Old Sep 14, 2010 | 05:08 PM
zaperroni's Avatar
zaperroni
Yeah, why not? Thats a good idea just to be sure, even though mine has lasted about a year so far without sanding.
Old Sep 14, 2010 | 05:11 PM
Z_enthusiast
true but all it takes is one rock to nick it then it could start peeling. not knocking you bro im just giving my 2cents
Old Sep 14, 2010 | 06:32 PM
zaperroni's Avatar
zaperroni
yea man i totally agree, i wish i sanded it just in case but no problems yet! *knock on wood* lol
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
