Electrical question
Old Sep 22, 2010 | 04:30 PM
G4nismo's Avatar
G4nismo
Default Electrical question
Say the max FV for an LED is 3.5v for example (not the typical voltage). If you can get it to be right under that, say 3.4v, is that ok or should I just get an adjustable voltage regulator and dial it to the typical range?
Old Sep 22, 2010 | 04:47 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
you should be able to run it at the max FV but dont expect it to last as long.
Old Sep 22, 2010 | 04:50 PM
G4nismo's Avatar
G4nismo
Yes, i know that. I want it to last as long as possible but with 0.1 V away from the max, would that decrease the life span of the LED significantly compared to if it was running at say 3v?
issyz
Jul 2, 2017 03:04 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Alexreyes
Sep 30, 2015 11:30 PM
