Replica Nismo V2 Bumper
Old Oct 21, 2010 | 07:24 AM
edgui12's Avatar
edgui12
Default Replica Nismo V2 Bumper
Ok, so i got my replica V2 bumper and im in the process of buying other parts and install everything on at once, my question is, (since i searched and found nothing) how do you guys, with replica bumpers, attach the fender liner to the bumper? or how did your shop do it? im trying to figure it out to make it look as clean as possible so any ideas would be greatly appreciated, thanks.
Old Oct 21, 2010 | 07:52 AM
Highway Riding's Avatar
Highway Riding
Good question.. My fender liner doesn't line up either... This is why the real Nimso V2 comes with everything including fender liner which i think is longer or has attachment points.
Old Oct 21, 2010 | 08:10 AM
Voboy's Avatar
Voboy
the nismo v2 uses 06-08 fender liners
Old Oct 21, 2010 | 08:26 AM
Highway Riding
Thanks
Old Oct 21, 2010 | 08:27 AM
cheshirecat79's Avatar
cheshirecat79
Yep- get new front liners (the fender liner for the front wheels have two pieces- front and back) from courtesyparts.
The front wheel front liner will bolt fine into your old front wheel rear liner.
Old Oct 21, 2010 | 08:49 AM
edgui12's Avatar
edgui12
Lol maybe my replica is just really cheap haha, got it from extreme dimensions and this is what the part where the original fender liner would connect to on the OEM bumper, but mine looks way different:
anyone have any experience with cheaper bumpers like this?
Old Oct 21, 2010 | 10:53 AM
cheshirecat79
You're going to have to drill the holes for the fender to mount on the bottom. You'll see what you need to do once you get the fender itself.
Old Oct 21, 2010 | 12:22 PM
edgui12's Avatar
edgui12
Lol but I mean for the fender LINER, you kno that nice black crappy plastic that goes in the wheel well to protect the engine bay and everything else from dirt and stuff like that??
Old Oct 21, 2010 | 12:26 PM
calin's Avatar
calin
If you have an 03-05 Z, then your fender liner will look like it's too small and won't line up correctly with the bumper. You'll need to get 06+ fender liners if you want them to line up. My friend had the same problem.
The reason for this is because the V2 bumper was designed for an 06+ Z
Old Oct 21, 2010 | 12:45 PM
cheshirecat79
Yeah, I get it. The 06+ fender liner tucks in on the side and bolts in the bottom.
Old Oct 21, 2010 | 02:33 PM
edgui12's Avatar
edgui12
Ohhh ok thanks, uhm I kno I can get em from the dealers anyone know where I can get em a bit cheaper? Also from what I read do I only need the front part of each front fender liner or both parts of the liner??
Thanks for all your help
Old Oct 21, 2010 | 02:48 PM
calin's Avatar
calin
My friend bought his from http://www.courtesyparts.com/
I'm not sure if you need both parts of just the front part though.
Old Oct 21, 2010 | 04:38 PM
edgui12's Avatar
edgui12
Ok thanks man, now anyone know if I need both or just one?
Old Oct 22, 2010 | 05:52 AM
cheshirecat79
Please see my reply above. I told you which liners you needed.
Old Oct 22, 2010 | 12:21 PM
edgui12's Avatar
edgui12
Ok thanks Cheshire, really appreciate it
Old Oct 26, 2010 | 07:09 AM
datboyvinh's Avatar
datboyvinh
With the nismo v2 bumper does the front bottom engine cover go on no problem?
Old Oct 26, 2010 | 07:14 AM
dkmesa350z's Avatar
dkmesa350z
I used a zip tie between the two outer most V2 mounting points to secure the my 03 fender liners when I had my V2. Not ideal, but I never had a problem with it (the holes in the fender liners are only a couple inches off from the holes in the bumper).
Old Oct 26, 2010 | 11:38 AM
datboyvinh's Avatar
datboyvinh
Did the bottom engine cover fit on the nismo v2 bumper on ur 03 350z? Lmk thanks
Old Oct 26, 2010 | 11:05 PM
Waiz's Avatar
Waiz
The V3 needs it's own bottom diffuser, the V1 and V2 work perfectly fine with the OEM version.
Old Oct 10, 2011 | 02:31 PM
WFjGer's Avatar
WFjGer
Searched high and low but cant find a good website to buy a replica V2 bumper. Any suggestions?
