How to Remove Shift Knob?
Old Nov 17, 2003 | 05:33 PM
dduck44's Avatar
dduck44
Default How to Remove Shift ****?
What's the easiest/safest way to remove the shift **** on a 6MT? I know it unscrews but it seems like the force is excessive.
Old Nov 17, 2003 | 05:39 PM
Natal's Avatar
Natal
It's not an easy task since it's pretty tight, but here's a link to a thread showing how-to.
Old Nov 18, 2003 | 05:54 AM
FRIT-Z's Avatar
FRIT-Z
Default Sparco Installed
I installed a dark blue Sparco shifter **** on my 6 speed m/t last night...just follow other members instructions and it's not hard.
Use a pair of vice grips under the **** well down on the shifter linkage...(protect with cloth or leather) and unscrew the ****, I used large channel locks...once you break it free just spin it off. The leather boot has a plastic ring around the top where it sits under the existing ****, if you put on a smaller diameter **** (bottom) I would remove this ring (you'll see what I mean). I just used a wire tie to hold the leather boot to the linkage under the new shifter ****...looks and feels good.
Frit-z
Good luck...should only take 30 - 60 minutes or so.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
