Custom LED Bumper Reflectors
I used the stock bumper reflectors, took them apart (CAREFULLY!!! They will break if you don't heat them up; I used a hair dryer) then used white LED strips I bought at Advance Auto. Cut them to size and applied them to the inside of the reflectors with the 3M tape supplied. After they were positioned inside where I wanted them (theres a slight curve to the reflector) I installed the stock amber reflector and used plastic weld epoxy to seal everything back up and make a weather tight bond. Once cured I installed them back in the bumper and borrowed power from the headlights parking light... and there yah have it! Homemade LED bumper reflectors!
Total cost: $25 for the LED strips and $7 for the epoxy.
where and how did you tap into the harness , ive got some led reflectors and im ready to tackle the job , i want them to come on when the parking lights come on . if you could tell me which harness and what color wires. any help would be greatly appreciated
You can remove the front bumper, which takes all of 10 minutes, or you can squeeze the reflectors in/out past the fender liners. Tougher on the right side, though, because of the windshield washer reservoir.
I've installed quite a few sets now, I 100% recommend taking off the bumper. After all the time spent trying to do it, busting knuckles and swearing you'll do trying to do it with the bumper on (and then you'll take it off to actually do it), you could have already had the bumper off!
