Is there a way to fix a FRP warp??
Old Nov 16, 2010 | 03:40 AM
RandyK1's Avatar
RandyK1
Default Is there a way to fix a FRP warp??
I got this bumper for a good deal but it has a warp or slight twist between the pipes. Is there an easy way to fix this?? Thanks p.s. I know about the gap below the tail lights, I can fix that
Old Nov 16, 2010 | 04:22 AM
KingBaby's Avatar
KingBaby
Hardest Setting
EDIT:
do this at your own risk!
heat gun!
am I'm being dead serious....if you can push or pull it to your liking. Kinda prop it to stay with what ever you have...
then hit it with the heat gun at about 6-10 inches away from the area...
so it well expand to the push or pull you have it at...then once it's cool to the touch again it should stay that way once to remove your push or pull or whatever
EDIT:
your not trying to heat it up at all...but make it warm cause you don't want to warp it with too much heat.
does that make sense I'm horrible at explaining stuff
Uriyo_
Sep 8, 2021 08:46 AM
Cashwin
Oct 1, 2015 06:36 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
