Is this scratch fixable with buffer?
Old Jan 19, 2011 | 06:00 PM
grey00lustre's Avatar
grey00lustre
Default Is this scratch fixable with buffer?
I believe I was a victim of vandalism since I notice my rear bumper is keyed. Is there any way to buff it out or fix it without painting the bumper? I was thinking of using thin coat of touch up paint then buff it after that. Or what's the best way to fix this?
Old Jan 19, 2011 | 06:13 PM
SuperBlack350z's Avatar
SuperBlack350z
it can be less visable but def can't be buffed out where it is gone. A light wetsand and heavy compound can smooth out the edges of that scratch where it doesn't look as bad but you will still have a scratch.
Old Jan 19, 2011 | 06:16 PM
Diesel350's Avatar
Diesel350
Like I said in your other thread. Wetsand and polish or paint are your options at this point. Looks like that scratch went pretty deep.
Old Jan 19, 2011 | 06:30 PM
grey00lustre
What type of wetsand paper should I use and what should I use to buff with? Would u guys suggest I skip touch up paint since it would look worst. I just want the scratch to look alot better then it is now.
Old Jan 19, 2011 | 06:34 PM
SuperBlack350z
you are going to need at least a 3k rpm high speed buffer. It's going to cost you around 200-250 for materials. i would have someone else do it or just get it repainted if you are spending that much.
Old Jan 19, 2011 | 06:36 PM
grey00lustre
I will see what local detailing shop would charge me. I just want the scratch to be less noticeable. This never happened to me where my car get keyped I'm kinda of pissed now.
Old Jan 19, 2011 | 09:34 PM
dcains's Avatar
dcains
I used this stuff to repair a similar scratch on my front bumper:
www.langka.com
It actually only works well if the scratch is deep (i.e. down to the plastic or metal), but if the scratch isn't fully through the color coat you may be able to polish it out.
Old Jan 19, 2011 | 11:02 PM
tyau's Avatar
tyau
That looks a little too deep even for wetsanding. You might have to fill it with touch up paint before wetsanding.
Old Jan 20, 2011 | 12:02 AM
bbs350z's Avatar
bbs350z
if it catches your fingernail easy, its beyond buffing out. i say use touch up paint and some light sanding to smooth the edges down as super black said. then buff from there. best of luck, vandalism sucks
Old Jan 20, 2011 | 06:38 PM
DBTre50z's Avatar
DBTre50z
That sucks dude. I had this happen to me, passenger rear quarter panel and the passenger door as well as some smaller marks on the bumper. Vandalism is such a cowardly move. In my case the passenger half of the car needs to be sprayed, so im waiting till spring to have it done. Hope everything works out for you. Marks like these can go through insurance without raising your rates so maybe you want to look into it.
Rev_Night
Nov 7, 2020 06:00 PM
