can you tell the difference ?
Old Jan 28, 2011 | 06:26 PM
s1n's Avatar
s1n
Exclamation can you tell the difference ?
ok can you tell the difference ? the one on the left cost 12.99 per yard and joaan's and the right cost 30.99 per yard at a upholstery supplier. i don't know which one to use err =\
:dun no::co nfused:
Old Jan 28, 2011 | 07:18 PM
Goo$e's Avatar
Goo$e
Picture quality sucks *****.
Old Jan 28, 2011 | 07:31 PM
s1n's Avatar
s1n
You can thank apple for that !
Old Jan 28, 2011 | 07:48 PM
erichsherrill's Avatar
erichsherrill
wheres this gonna go is this suede?
Old Jan 28, 2011 | 08:33 PM
s1n's Avatar
s1n
yes it BLACK sueded and i am going to use it for the headliner
Old Jan 28, 2011 | 08:36 PM
ITOzann's Avatar
ITOzann
ya.
Old Jan 28, 2011 | 08:55 PM
I would go with $30.99/yard because no one wants cheap stuff in their car.
Old Jan 28, 2011 | 08:57 PM
gixxert's Avatar
gixxert
go with which ever one stretches more. if you use stiffer stuff youll be redoing it like i have too
Old Jan 28, 2011 | 09:01 PM
omsin523's Avatar
omsin523
one has more wrinkles
Old Jan 28, 2011 | 09:27 PM
Strollo22's Avatar
Strollo22
Difference is in the thread count, just like sheets. The more expensive one is likely more durable and will last longer and probably easier to work with.
Old Jan 28, 2011 | 09:36 PM
sdZ33's Avatar
sdZ33
I get some suede headliner jobs a couple of times a month(side jobs), and I tried to save a few bucks one time and I ended up buying suede from Joanne's instead of the usual place I go to...
The suede from joanne's is by far a thinner fabric and it feels way different from the other fabric... Different as in, the fabric from my usual place is softer, smoother, and thicker... The Joanne fabric, was thinner, and soaked up the spray adhesive so much that it bled through and the suede was ruined...
So, long story short, I tried to save a few bucks and go the Joanne route and it ended up costing me more than if I went with the suede I usually use from the other place...
I used the same spray adhesive I always use, so I know it had to be the fabric from Joanne's...
I've read that other people have used the suede from Joanne's without a problem, but this was my experience...
OP, just compare the fabrics and get the one YOU think will be best for YOU... If you can't decide, I would suggest you leave it to a professional...
Old Jan 28, 2011 | 09:44 PM
Chebosto's Avatar
Chebosto
whatever material feels the best against bare *** should be the choice.
Old Jan 28, 2011 | 10:43 PM
KingBaby's Avatar
KingBaby
Hardest Setting
agreed...
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
