06 headlight swap in base 05
Old Jan 29, 2011 | 05:05 AM
ovalnegri's Avatar
ovalnegri
Default 06 headlight swap in base 05
Flame all u want, but the search hear $u@%!!! I can't find a good DIY with photos for mounting 06' headlights to a base 05. Can anyone point me to one. I have found in other forums and there is one in wikipedia, doing searches in the internet, but none have photos. There is one for RETROFIRING with photos, but that's not it. Help would be appreciated since I have some questions about the project in hand.
Old Jan 29, 2011 | 11:45 AM
sdZ33's Avatar
sdZ33
oh simon
Old Jan 29, 2011 | 01:01 PM
cubs4worldseris's Avatar
cubs4worldseris
I hope your car has HID bulbs in it now.
Disconnect your battery, pull off the front bumper, remove the three or so screws that hold each headlight unit in place, remove the ballast, screw ballast into bottom of new headlight units, hook up all wiring, replace screws in the same exact place, replace bumper, reconnect battery...DONE
It's really not hard at all, I did it with NO diy instructions and NO pictures.
Keep in mind that you may want to replace the 168 amber daylight running bulb with a 5000k or 6000k led bulb for looks.
Old Jan 29, 2011 | 03:40 PM
NismoZR's Avatar
NismoZR
I hope this will help http://www.wikiautorepair.org/wiki/N..._Lights#Videos.
Old Jan 30, 2011 | 05:28 AM
ovalnegri's Avatar
ovalnegri
to: cubs4worldseris
That's the thing, I don't have HID, I'm totally stock so this is from scratch.
to: NismoZR
I have that DIY, my question from it is, do I have to cut something from 05 headlights?
Old Feb 2, 2011 | 10:11 PM
MIX350Z's Avatar
MIX350Z
Are you looking for a DIY on changing the 8pin plug on the 06 headlight to the 6 pin plug layout of the base 03-05 headlights?
Old Feb 3, 2011 | 07:17 AM
ovalnegri's Avatar
ovalnegri
basically, I know I can also go the other way; changing de 6pin plug from the engine side to the 8ping of an HID. I want photos, the instructions of the ones I found are good, but none have photos. I want to be sure.
Old Feb 3, 2011 | 09:45 AM
tquill's Avatar
tquill
https://my350z.com/forum/body-interi...eadlights.html
Old Feb 3, 2011 | 11:03 AM
STL 350Z's Avatar
STL 350Z
Originally Posted by NismoZR
I have been looking for something like this for a LONG time... THANK YOU!
Old Feb 5, 2011 | 08:01 AM
ovalnegri's Avatar
ovalnegri
WOW , I had seen this DYI, but didn't look closely at the photos. I assumed by the title that it wouldn't help me. FAIL
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
