06+ Bi-xenon Headlight Problem
Old Feb 6, 2011 | 01:34 PM
tcho's Avatar
tcho
Default 06+ Bi-xenon Headlight Problem
Hi all,
Last night I realized that the passenger headlight did not turn on. So I just figured that the bulb had died. But my friend told me that it could be a problem with the fuse or the ballast. Now I'm just confused and lost. I did put in new alpine stereo in front a couple of days ago...could that be a problem? I'm gonna stop by a shop during this week but just would like to know what you guys all think. I don't wanna go in to the shop not having any knowledge at this. Although I can flirt with wrench and hammer, I'm pretty stupid with electrical stuff.
Thanks in advanced!
Old Feb 6, 2011 | 01:50 PM
Venom8.1's Avatar
Venom8.1
i had this problem.....It was the fuse....in the back of battery
Old Feb 6, 2011 | 01:58 PM
tcho's Avatar
tcho
o dang, did u change the fuse urself? I don't even know where to get the fuse if that was the problem. Btw, was there any problems after the change Venom? If this is more than one time thing, I'm taking the stereos out
Old Feb 6, 2011 | 06:29 PM
Marcus93's Avatar
Marcus93
All you do is pull the fuse out, and replace with a new one. You can buy them from any auto store. The fuse box he's talking about is under the hood in the same compartment as the battery.
Old Feb 6, 2011 | 10:33 PM
bbs350z's Avatar
bbs350z
if the fuse is shot, the metal inside the plastic housing should be burnt or broke in half. happened on my evo, the whole driver side went out. easy fix.
usually when an hid starts to go bad, itll turn purple-ish and flicker, and turn off occasionally
Old Feb 7, 2011 | 04:59 AM
Blck350z's Avatar
Blck350z
I would check items in this order....
-Fuse first (like everyone said with the battery
-Then the HID bulb ( when you pull it out it will be burnt inside the glass housing.
-the ballast (See its current rating by connecting an
ammeter between the lamp socket center pin and the socket shell)
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
