Harness Install
Old Feb 9, 2011 | 01:36 PM
GeauxLadyZ's Avatar
GeauxLadyZ
This way:
Old Feb 9, 2011 | 03:26 PM
07_z33's Avatar
07_z33
^sex!!! that pic just motivates me to spend more monies on more jdm goodies.
Old Feb 9, 2011 | 03:28 PM
f-350z's Avatar
f-350z
OMG
Old Feb 9, 2011 | 03:39 PM
terrasmak's Avatar
Originally Posted by f-350z
^ looks fine means nothing wrong with it, I didnot mean they look good or better
2 things wrong with it. It can easily cause 1 or both of these uncurable conditions if you get in a wreck
1. Broken back, not curable, lifetime of pain.
2. Death
Old Feb 9, 2011 | 03:58 PM
f-350z's Avatar
f-350z
^ thanks for the clarification
Old Feb 9, 2011 | 06:45 PM
daniel.sepe's Avatar
daniel.sepe
Originally Posted by GeauxLadyZ
This way:
beauty picture!! thank you!
Old Feb 9, 2011 | 08:23 PM
JDMStanced's Avatar
JDMStanced
Originally Posted by scotts300
The only parts that should be mounted to the floor are the lap belts and the sub strap.
but lap belts will be mounted to the stock location, right? removing the stock bolts to eye bolts
Old Feb 9, 2011 | 09:05 PM
daniel.sepe
yeah and you put the harness clip into the eye bolt!
scotts300's Avatar
scotts300
People do that - yes. I did not as that exceeded the suggested distance between the lap belt mounting point and the seat/back intersection: http://www.gforce.com/pdf/Harness_Install_Info.pdf
I drilled holes into the floor and installed eye bolts with metal backing plates underneath.
Old Feb 9, 2011 | 09:16 PM
JDMStanced's Avatar
JDMStanced
i could just use the stock location until i get a bucket seat.
About installing the eye bolt for sub belt, do you recommend, 1) cut the stud on eye bolt and weld it on the floor. No backing plate or whatever. or 2) drill a hole and use the backing plates.
I talked to a fab guy who is working on my custom harness bar, he recommended welding since its stronger and easier.
Old Feb 9, 2011 | 11:28 PM
terrasmak's Avatar
B. Drill a hole and weld the backing plate to the floor.
Old Feb 10, 2011 | 06:28 AM
daniel.sepe
good call.
Old Feb 10, 2011 | 10:28 AM
Twenty4's Avatar
Twenty4
if you pull out your carpet, there is a hole in the transmission tunnel that mirrors the stock lap belt bolt hole, just use a backing plate and an eye bolt there and its perfect. Im almost positive nissan did that on purpose.....
Old Feb 11, 2011 | 04:52 AM
daniel.sepe
reallly?? **** k i might check that out im just not to sure if i want to pull out the carpet
Old Feb 11, 2011 | 09:31 AM
terrasmak's Avatar
Lift up carpet , find hole, small cut thru carpet, install belt.
Old Feb 11, 2011 | 09:43 AM
blue350zed's Avatar
blue350zed
Shouldn't the eye bolts on the floor for the lap harnesses be mounted where the harnesses are pulling directly out on them, instead of at a 90 degree angle like it would be if mounted to the transmission tunnel? Thought I saw that somewhere.
Old Feb 11, 2011 | 11:42 AM
ExtaZ33's Avatar
ExtaZ33
For reference, this is the backing plate I used in the transmission tunnel.
http://www.sparcousa.com/pharness_comp.asp?id=479
Old Feb 11, 2011 | 12:50 PM
  #38
JDMStanced's Avatar
JDMStanced
how do we go about torquing down the eye bolts that replaced the stock lap bolts?
Old Feb 11, 2011 | 04:12 PM
  #39
Twenty4's Avatar
Twenty4
they need to be at about 45 degrees from your waist. where my seat is and the stock belt hole plus the hole that was already in the tunnel its just about perfect
Old Feb 11, 2011 | 04:34 PM
  #40
blue350zed's Avatar
blue350zed
I don't really mean where they should be mounted in accordance to the seat location, but the angle at which they pull on the eye-bolt. Shouldn't it pull directly out on the eye-bolt instead of at an angel? This way, it doesn't break the eye-bolt off under sudden or hard pull. Wish I could find that picture again to be more specific.
