rear overfenders
Old Feb 12, 2011 | 08:49 PM
cbcm2435's Avatar
cbcm2435
Default rear overfenders
the only ones ive seen are the seibon ones, is there other companys that make wider fenders that are not part of a widebody kit, if so post up pics
Old Feb 12, 2011 | 10:17 PM
R3belzBRN's Avatar
R3belzBRN
err do luck i guess
Old Feb 12, 2011 | 10:44 PM
cbcm2435's Avatar
cbcm2435
i just found those ones, they are expensive, ones for the 240 are like $400
Old Feb 12, 2011 | 11:10 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Well Nismo makes a rear flare piece. Blitz made an overfender kit for all 4 corners... Its long been discontinued. All your other options are wide bodies: BRS, Do luck, MasterGrade(discontinued), Asuka(discontinued), Veilside, Buddy Club(discontinued), Amuse, and some other ones I cant think of
Old Feb 12, 2011 | 11:20 PM
cbcm2435's Avatar
cbcm2435
im looking for something that will work with other kits, and ive found the seibon ones and the do-luck ones, i was just wondering if there is any more, im surprised there isnt they are really popular with almost every other car
Old Feb 12, 2011 | 11:37 PM
bbs350z's Avatar
bbs350z
what exactly are you looking to do exactly? fit larger wheels or go widebody? ive seen a few custom fenders that were cut, pulled, and redone to look oem but wider
Old Feb 13, 2011 | 10:51 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
I believe the seibon ones are replicas of the do-luck ones. If not they look VERY similar. Personally i don't like them as the ruin the lines of the car at the back.
How exactly does the fender cut and pull work, as i would like to get it done on my car too?
Old Feb 14, 2011 | 09:19 AM
bmccann101's Avatar
bmccann101
Default fenders
not sure what exactly you meant in terms of direction ( fender pull).. but Intense did a yellow widebody Z along with a Wald kit, and used steel to remake the fenders using the same body lines as OEM.. not a cheap endeavor, fully fab custom. You can find it on thier website, and its sick, something like 900 hp.
In terms of aftermarket fender cutting, the fender gets mounted to the car, and the new outside wheel well gets traced w a rgease pen to the fender.. you make several cuts up from the wheel and fold them in and tack weld them all. Rubber mallet bends them well, and smooths it out. Just cutting material out or not welding leaves jsut that.. a hole.
Not sound.
Needs to be cut, bent and rewelded. Ran me about 700 bucks to have them cut out. Not cutting fenders for widebody defeats the purpose of wider wheels IMO.
Hope that helps.. wide fenders are not a cheap endeavor in the least bit.
Old Feb 15, 2011 | 06:16 PM
buzzardmountain's Avatar
buzzardmountain
The Seibon ones aren't exact replica's. Someone was dipping in the sauce when they "replicated" the Do-Luck. Seibon's rear fenders are only 10mm front/10mm rear.
Authentic Do-Luck is 10mm front/30mm rear.
