Gutting hood?
Old Apr 12, 2011 | 07:18 PM
JDMStanced's Avatar
JDMStanced
Default Gutting hood?
After having to compare weight between seibon TS II and VS II, TS II was surprisingly lighter than stock. VS II, not much. However i had to choose VS II for some reason; now it's on my car
Would it be a wise thing to gut out the hood skeleton? I asked this to Chris Forseberg, and he said it's ok. Most of his hoods are gutted inside.
So if i decide to gut out, do i simply gut out anything that is not glued to the hood?
Old Apr 12, 2011 | 08:11 PM
ImWeeZzel's Avatar
ImWeeZzel
I wouldn't recommend gutting it out, you'll loose the support and could end up cracking your hood. I'm sure a guy like chris foresburg can afford to get replacements all day long
out of curiosity, how much weight could you possibly save by cutting the hood?
Old Apr 12, 2011 | 08:16 PM
JDMStanced's Avatar
JDMStanced
TS II was really light and flexible. the hood would flex when i try to latch the hood.
Light weight hood doesn't require your guns to raise it haha
Old Apr 12, 2011 | 08:17 PM
skakemokid's Avatar
skakemokid
Who cares about cracking?? Its for weight reduction.. Do it kris.. JUST MAKE SURE YOU HAVE HOOD PINS..
Old Apr 12, 2011 | 08:22 PM
JDMStanced's Avatar
JDMStanced
That's what i'm talking about i also asked forseberg if gutting it out will mess up the clear coat. Answer was no i want to hear from "normal" people though
installing sparco hood pins tomorrow
Old Apr 12, 2011 | 08:30 PM
ImWeeZzel's Avatar
ImWeeZzel
could you update with weight specs when you do so? I have a spare seibon vt hood that I could try this on.
i have a seibon ts hood on the way, mainly for cosmetic purposes. I didn't know if you didn't care about damaging your hood, so don't take things the wrong way.
Old Apr 12, 2011 | 08:35 PM
JDMStanced's Avatar
JDMStanced
Not going to take off the hood from the car. I could weight the amount of material i cut, which won't be much lol
Can you gut you "spare" hood rather than i gutting my only hood?
Old Apr 12, 2011 | 08:41 PM
ImWeeZzel's Avatar
ImWeeZzel
I'm actually trying to sell it and try to make up for some of the cost since I messed up while trying to install aero catch hood latches.
If you were local I'd give you a hell of a deal
Old Apr 12, 2011 | 08:47 PM
JDMStanced's Avatar
JDMStanced
not a fan of vt hood.
Did you call Aero Deisgn today?
Old Apr 12, 2011 | 08:49 PM
skakemokid's Avatar
skakemokid
ONLY HOOD? wheres your old one?
Old Apr 12, 2011 | 08:51 PM
JDMStanced's Avatar
JDMStanced
Prolly gonna sell it.
6 tires, a set of 17" wheels, hood, and rear bumper do not work in a single garage. I'll be putting a set of 17" gramlight in my garage too..
Old Apr 13, 2011 | 08:17 AM
R350Zz33's Avatar
R350Zz33
Hang it from the roof
Old Apr 13, 2011 | 08:54 AM
bagged00's Avatar
bagged00
so your wanting to cut all the reinforcement out from under the hood skin? ive never seen what a carbon fiber one looks like underneath but cutting it out of a steel hood would be a problem and i got to imagine a cf hood would be a problem too. not only are you taking the structure of the hood out of it causeing it to be thin, but that structure is also there for collision reasons. with no reinforcement underneath it, itd probably shatter in a front collision.
Old Apr 13, 2011 | 09:05 AM
terrasmak's Avatar
The hood folds in a collision, it is made to fold, thats what the hooks in the back do. A CF hood will also fold in collision.
IMO, not worth it unless its in a dedicated race car.
Old Apr 13, 2011 | 09:12 AM
ImWeeZzel's Avatar
ImWeeZzel
@bagged
The under side of a cf (seibon brand) is made out if fiber glass. Its pretty thick and a little difficult to cut into without ripping thru the other side. I think in an event of a collision, the cf hood would snap, break, shatter etc
Old Apr 13, 2011 | 09:26 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it flexed because it's fiberglass and because you're trying to support it on only 1 side...my TSII was heavier than stock by 1.6 lbs, and "leaned" when using the hood prop.
Old Apr 13, 2011 | 08:41 PM
JDMStanced's Avatar
JDMStanced
The seller told me that they are FRP not fiberglass. (dunno the difference).
The TS II and my VS II are both FRP structure with 1 piece carbon fiber or whatever.
TS II was light and flexible (Definitely lighter than stock). VS II is heavy and not flexible.
Today i installed my sparco hood pins. I had some fun cutting the underside of the hood lol.
it was like snow falling. Pretty fun.
i'd go crazy on cutting the underside when i'm bored lol
EDIT: my stock strut doesnt fit so i need to gut that area anyways
Old Apr 14, 2011 | 04:18 AM
Z1 Performance
Former Sponsor
FRP (fiber reinforced plastic/polymer) is fiberglass. The hoods are fiberglass, the carbon is wrapped on top to give it the carbon look
Old Apr 14, 2011 | 10:18 PM
JDMStanced's Avatar
JDMStanced
gutting hood may not be a good idea especially toward the front windshield area.
i drove around with my hood and hood spacers on. The end of the hood toward the front windshield shakes, flexes up and down at speed. Hope it doesn't stress the clear coat or carbon fiber over time.
Old Apr 15, 2011 | 04:58 AM
Z1 Performance
Former Sponsor
there is no clear coat on it, and yes, any amount of flex will eventually lead to separation of materials
