Gutting hood?
Old Apr 15, 2011 | 06:16 AM
terrasmak's Avatar
Problem
Originally Posted by JDMStanced
gutting hood may not be a good idea especially toward the front windshield area.
i drove around with my hood and hood spacers on. The end of the hood toward the front windshield shakes, flexes up and down at speed. Hope it doesn't stress the clear coat or carbon fiber over time.
Answer
Originally Posted by ImWeeZzel
I wouldn't recommend gutting it out, you'll loose the support and could end up cracking your hood. I'm sure a guy like chris foresburg can afford to get replacements all day long
Old Apr 16, 2011 | 05:58 PM
JDMStanced's Avatar
JDMStanced
I don't want to make a new thread so I'll ask here.
when you install sparco hood pins, do you install em so that when you close the hood and pins, you have to push down on the hood?
don't think im making much sense..
basically, does the hood have to be kept closed by hood pins, not the latch?
Old Apr 18, 2011 | 03:10 PM
JDMStanced's Avatar
JDMStanced
bump
Old Apr 18, 2011 | 04:12 PM
skakemokid's Avatar
skakemokid
you can have both if you want kris, If you use the latch, teh pins will be extra insurance that it doesnt come flying at you .
Old Apr 18, 2011 | 05:17 PM
JDMStanced's Avatar
JDMStanced
Old Aug 8, 2021 | 03:13 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Originally Posted by bagged00
so your wanting to cut all the reinforcement out from under the hood skin? ive never seen what a carbon fiber one looks like underneath but cutting it out of a steel hood would be a problem and i got to imagine a cf hood would be a problem too. not only are you taking the structure of the hood out of it causeing it to be thin, but that structure is also there for collision reasons. with no reinforcement underneath it, itd probably shatter in a front collision.
Hood isn't there for collision purposes only to cover your engine bay. Your front absorber and reinforcement are for collision purposes
Old Aug 9, 2021 | 09:26 PM
bealljk's Avatar
bealljk
I can’t imagine the good has much crash impact value (maybe a little??)
if I remember correctly an OEM hood is around 21lbs?? And gutted its around 14lbs …
you will see the hood flex & move around a bit at speeds over 100mph - 120mph … was somewhat worried about it when I did the Kansas event.
not horrible for free weight reduction over the front of the car…
Old Aug 10, 2021 | 07:23 AM
DarkZ03's Avatar
DarkZ03
I have flex on the CF hood it's sketchy, you run pins or anything?
Old Aug 10, 2021 | 07:29 AM
bealljk's Avatar
bealljk
yea, I definitely have flex too … I have the rectangles cut out for my vents and I haven’t installed them either …
Yea, hood pins, I am not a fan of them but necessary evil I guess…
Old Aug 10, 2021 | 08:51 AM
DarkZ03's Avatar
DarkZ03
I've been procrastinating getting mine installed, I don't like the look of pins but I don't need my hood coming up on me either.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
EnjukuRacing
Misc.
Sep 23, 2015 07:27 AM
jdmctrek
Exterior
Sep 17, 2015 03:13 PM
Wu-Watt
East Canada
Sep 12, 2015 07:31 AM
