3M ScotchPrint Brushed Aluminum Vinyl on Steering Wheel
Old May 8, 2011 | 02:13 PM
Diesel350's Avatar
Diesel350
Default 3M ScotchPrint Brushed Aluminum Vinyl on Steering Wheel
My plastic trim pieces on my steering wheel have shown quite a bit of wear after 74,000 miles and since it's quite expensive to replace those trim pieces I decided to use 3M's Brushed Aluminum Vinyl. Application was pretty easy, you just need lots of patience.
Tools used:
Isopropyl Alcohol- To clean pieces
3M Primer 94- Applied to edges and curves so vinyl stays in place.
Application Squeege- Helps with getting vinyl down in tight spaces and gets out any air bubbles.
Exacto Knife-Needed to cut away vinyl in tight places
Hair Dryer- Needed to stretch vinyl over curves and edges.
Now what I did was take a screwdriver and take out the two screws on each side of the steering wheel behind the trim pieces. This allowed me a bit more room to work with the vinyl. Now these trim pieces simply DO NOT pop off. In order to get them completely off you have to have a special Torx bit that I believe you can get at Sears that will allow you to take the Steering wheel apart and gain you access to the screw that is holding the trim piece to the steering wheel. So I decided to apply the vinyl while the trim pieces where still attached to the steering wheel. A bit more tricky but not a big pain in the butt to completely take your steering wheel apart.
Now on to the pics:
Left side Before:
left side After:
Right Side After:
Right side done, left side unfinished:
Completed:
Here are a few other samples of vinyl I got:
Silver 3M Di-NOC Carbon Fiber
Anthracite 3M ScotchPrint 1080 Carbon Vinyl
3M Scotchprint Brushed Titanium Vinyl compared to the brushed aluminum vinyl behind it and the Silver and Anthracite Vinyl
Old May 8, 2011 | 02:21 PM
STL 350Z's Avatar
STL 350Z
Not sure if I like it... in this pic it looks like silver wood grain.
Old May 8, 2011 | 02:22 PM
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
Old May 8, 2011 | 04:59 PM
Looks brand new. Excellent choice of vinyl.
Old May 8, 2011 | 06:28 PM
ap2_S2Kyle's Avatar
ap2_S2Kyle
good job man...mines starting to look like that.. -_-
Old May 8, 2011 | 09:43 PM
terrasmak's Avatar
Nice work,
Old May 8, 2011 | 09:51 PM
KingBaby's Avatar
KingBaby
Hardest Setting
wow....very oem!
I like it
Old May 10, 2011 | 08:36 AM
68Stang's Avatar
68Stang
Now if somebody would sell them precut and with the cruise control labels pre-printed on them...
Old May 11, 2011 | 04:34 PM
Diesel350's Avatar
Diesel350
Just did the passenger door handle since it was already all scratched up.
Before:
After:
Old May 11, 2011 | 07:54 PM
BoomerZ33's Avatar
BoomerZ33
nice way to get rid of those annoying scratches!
Old May 11, 2011 | 08:05 PM
marques1's Avatar
marques1
Thanks, I will have to get this done.
Old May 12, 2011 | 06:00 AM
vtecsux's Avatar
vtecsux
+1
Old May 12, 2011 | 11:49 AM
Highway Riding's Avatar
Highway Riding
Thx for sharing. I got mad scratches to rid myself of.
Obadabot
Jun 18, 2023 11:31 PM
