EVO-R or Tein or NRG hood dampers
Old May 27, 2011 | 11:03 PM
BlueDragonZ's Avatar
BlueDragonZ
[QUOTE=Kuhan;9171191]I finally had time to install the EVO-R hood dampers. The install was simple and took me about 20 minutes or so.
I really like these since no trimming was required, and they have 2-stage opening, which is pretty cool.
Here are some pictures.
No trimming needed
stage 1 (for car show etc.)
Awesome thanks for this. I never liked the fact that I had to trim with NRG. My brake and brake fluid covers are painted so I didn't want to mess that up.
Old May 27, 2011 | 11:04 PM
BlueDragonZ
Old May 28, 2011 | 06:32 AM
sluggoZ's Avatar
sluggoZ
Kuhan....nice job! Looks great!
BlueDragonZ...installing the NRG, the small 'dremel' trim is on the lower black plastic cover which has nothing to do with your battery & brake fluid covers...you removed them first.
Old May 28, 2011 | 08:49 AM
BlueDragonZ
I should have said those trim pieces that holds the battery/fluid covers are painted on mine.
Old May 28, 2011 | 09:06 AM
Kuhan's Avatar
Kuhan
^Nice engine bay.
No problem, guys. If you have any questions, let me know.
Wais, you know you want these.
Old Jun 19, 2011 | 04:33 PM
dcains's Avatar
dcains
I just installed a set of the NRG polished struts on my '08. They look and work great, 20-minute install, no cutting.
Old Jun 24, 2011 | 08:55 PM
mshahidz's Avatar
mshahidz
has anyone tried these on an aftermarket hood? I have an ASM hood and im afriad of the dampers being too stiff that the hood will be damaged from pressure
Old Jun 24, 2011 | 09:01 PM
omsin523's Avatar
omsin523
They make some for aftermarket hoods
Old Jul 12, 2011 | 10:03 AM
corsairprime's Avatar
corsairprime
Default Go with the EVO-R units
I just installed the EVO-R dampers on my 2006 350Z and installation was painless. No cutting or grinding. Top marks for ease of install.
link to my pictures:
https://picasaweb.google.com/corsair...62707254496594
Corsairprime.
Old Jul 13, 2011 | 08:20 PM
Saudi's Avatar
Saudi
so are the evo-r's the only ones that are dual stage?
edited for dumb question....
Old Jul 13, 2011 | 09:16 PM
dcains's Avatar
dcains
Corsairprime.
The distinction between the different brands seems pretty blurry, and may depend on where the "brands" are sourcing their parts. My NRG's look exactly like these EV-R's, except for the polished finish (the brackets are exactly the same), but different from other NRG pics I've seen posted.
Old May 31, 2012 | 09:21 AM
ntwillie1's Avatar
ntwillie1
Kuhan and other guys that have the EVO-Rs, quick question.
Should I be able to compress the damper by hand? I am about to install mine but I can't get them to budge an inch. I got them for xmas like 2 years ago and never had time to install. I figured I have a few min today so I was going to attempt it. I don't want to put it on my car and it ends up not compressing and letting my hood down and then I have to uninstall. Thanks in advance.
Old May 31, 2012 | 10:49 AM
dcains's Avatar
dcains
I couldn't compress mine, but I didn't really try all that hard. I suppose if you could put enough force on one to compress it, the ends would puncture your hands Don't worry, the hood has much more leverage because the struts are mounted so close to the hinges.
Old May 31, 2012 | 10:55 AM
ntwillie1's Avatar
ntwillie1
Thanks man. I guess I'll go ahead and do mine then. I just wanted to make sure they weren't defective. Either that or I didn't eat my wheaties today.
Old May 31, 2012 | 01:27 PM
taywan's Avatar
taywan
I got some from a seller and said to be nrg but I'm not sure if they are. But no probs so far. Hood goes way up but fine w me. Seems to be ok.
Old May 31, 2012 | 09:16 PM
graffkid732's Avatar
graffkid732
Took 2 years to get a few minutes to install them? Hah. Or you completely forgot you had them?
Old Jun 1, 2012 | 08:56 AM
sluggoZ's Avatar
sluggoZ
NRG has their logo on each damper. Best to compress first.
There are some real cheapies out there from China.
Old Jun 1, 2012 | 10:26 AM
  #38
ntwillie1's Avatar
ntwillie1
Well. I forgot to make time to install them. Anyway, just did em. Not bad. Quite a bit of resistance closing it at first. But I finally got it to close right before they popped off the hinges. I opened and closed a few more times and it's a little better. I will let it break in.
Old Jul 6, 2012 | 07:41 PM
  #39
b18ccivics's Avatar
b18ccivics
are there any struts that mount to the fenders closer to the hinges then farther out on the hood. I dont really like the mounting at the hinges, the hood is not designed for this and flexes and that is not to good with aluminum.
Old Jul 9, 2012 | 02:36 AM
  #40
sluggoZ's Avatar
sluggoZ
I have no problems whatsoever with NRG. The trick is to compress the struts several times before installing & grease the bearings. Hood stays up & closes perfectly.
