EVO-R or Tein or NRG hood dampers
Old May 12, 2011 | 04:48 AM
Kuhan's Avatar
Kuhan
Default EVO-R or Tein or NRG hood dampers
Which one do you have and recommend?
I can get brand new Tein dampers for $95 shipped, or $110 for Evo-R or $145 for NRG.
I like the carbon fiber version.
Any feedback would be appreciated. Thanks.
Old May 12, 2011 | 04:51 AM
Kuhan's Avatar
Kuhan
Tein
Evo-r
NRG
Old May 12, 2011 | 04:56 AM
FATPUBUS's Avatar
FATPUBUS
I have polished NRG dampers...no problems 1 1/2 year of use so far. The Tein will clash with your engine bay whether you have any bling or not. Dunno bout the Evo-r.
Old May 12, 2011 | 05:16 AM
omsin523's Avatar
omsin523
Im running the nrg polished no problems good fitment, I remember ive read a while I was looking for these dampers the tien's had some problem but, I dont remember what it was.
Old May 12, 2011 | 05:30 AM
can'tZme's Avatar
can'tZme
I've got the EVO-R dampers from "the Z store" and they work great.
Old May 12, 2011 | 05:52 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
I have the NRG's and they were a 10min install... even with the small trim work I did.
You can barely see it.. but I cut about a 2mm half circle off the Battery and Brake Master cylinder cover with a dremel. You can actually see a half circle on the plastic... so you cut that out and BAM!!!! it look's like it was meant to be there.
Old May 12, 2011 | 06:19 AM
BoomerZ33's Avatar
BoomerZ33
i have polished NRG and wrapped it with 3M dinoc
Old May 12, 2011 | 06:33 AM
chrisjersey06's Avatar
chrisjersey06
I have the Evo-R ones and they work great, and no cutting needed to install. I chose them because they are 2-stage instead of single stage like the rest, so I can keep the hood half open for car shows.
Old May 12, 2011 | 06:43 AM
NA&CH's Avatar
NA&CH
Man your car looks so clean. Love it. And that is a neat option on the Evo-r's. This I did not know.
I have the NRG's and take about 10-15 mins. They work great. Got mine fo $70 in the marketplace.
Chris
Old May 12, 2011 | 06:51 AM
ImWeeZzel's Avatar
ImWeeZzel
where can you get tein hood dampers for 95 bucks??? Btw those brackets in the pics of the tein hood dampers are a different design...
Old May 12, 2011 | 07:04 AM
Kuhan's Avatar
Kuhan
^I found the Tein pic off google, probably not for 350z.
If you want Tein dampers, pm me and I'll send you his info.
I'm thinking of going with EVO-R ones.
Old May 12, 2011 | 07:17 AM
abushong504's Avatar
abushong504
I would not go with tein. They are super stiff. I ended up selling mine because I could not get them to loosen up at all. I can't say anything else about the others. I know that Evo-R makes theirs so that you do not have to cut the plastic piece in order to get to the screw location. Other than that, that is all I can tell you.
Old May 12, 2011 | 09:26 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
So Teins are the only ones that require you to trim?
Old May 12, 2011 | 09:57 AM
Kuhan's Avatar
Kuhan
^Tein and NRG do. EVO-R ones don't require trimming the plastic cover.
Old May 12, 2011 | 11:32 AM
NA&CH's Avatar
NA&CH
The plastic you trim is the size of a nickle. But no trim = tEh win!
Chris
Old May 12, 2011 | 01:46 PM
Kuhan's Avatar
Kuhan
Just ordered the EVO-R cf hood dampers from thezstore.com.
Will give a feedback when installed.
Old May 13, 2011 | 11:07 AM
JohnG202's Avatar
JohnG202
I put the EVO-R CF on a month ago and I needed to trim the plastic, not a big deal. Mine also look different than what they have pictured on the website (zstore). There's a gold ring at the top of the piston where it connects to the hood and a chrome ring at the bottom. I Don't like the gold with my silver car. Not sure if they sent the wrong model or what. The function of the dampers is great. I'll probably black out the gold ring or something.
Old May 16, 2011 | 11:38 AM
sluggoZ's Avatar
sluggoZ
I love my NRG polished ss hood damper kit.......carbon fiber is for cf hoods.
MrWong a vendor here has a great shipped priced if anyone else is interested.
Size:  40.2 KB Name:  DSC01495.jpg
Old May 27, 2011 | 08:39 PM
Kuhan's Avatar
Kuhan
I finally had time to install the EVO-R hood dampers. The install was simple and took me about 20 minutes or so.
I really like these since no trimming was required, and they have 2-stage opening, which is pretty cool.
Here are some pictures.
Unpacked
Installed
No trimming needed
stage 1 (for car show etc.)
stage 2 (all the way up)
Old May 27, 2011 | 09:23 PM
Waiz's Avatar
Waiz
Looks like your Z is giving me one of these
