What would you do?
Old Jun 24, 2011 | 05:30 AM
TJGILROY's Avatar
TJGILROY
Default What would you do?
Well, after washing my car and seeing it in different lighting after getting it from the shop, it seems there is light overspay on the rear. The front is what got damaged and was fixed but it seems some random overspray got on the rear of my car and it looks to be clear coat...
Should I try to get this off myself or take it to the shop and tell them to fix it?
- and it doesn't help it has to be at a certain angle and the right light to see these random blemishes
Old Jun 24, 2011 | 05:43 AM
TJGILROY's Avatar
TJGILROY
sorry, here is a pic, it's hard to get a good one because of the angle and lighting you have to be at to see the blemishes
this is one around the rear turn signal
there is about six other random spots on the back of the car like this
Old Jun 24, 2011 | 06:13 AM
gvulakh's Avatar
gvulakh
Take it back to the shop that did the work. They should be able to fix this easily.
Old Jun 24, 2011 | 06:14 AM
TJGILROY's Avatar
TJGILROY
taking it during my lunch break...i have a feeling they are going to be difficult though and think i am just nitpicking
Old Jun 24, 2011 | 06:18 AM
gvulakh's Avatar
gvulakh
They didn't do your bodywork for free did they? It's their fault for not being thorough enough when masking off the back of the car to paint the front.
Just don't go in there hot-headed. Calmly show them their mistakes and they should be able to sand/buff this stuff out.
Old Jun 24, 2011 | 06:29 AM
TJGILROY's Avatar
TJGILROY
yeah, i've been level headed with them the whole time but now just kind of upset i'm having to go through all of this
but clear coat overspray can be buffed out? that would be a relief
Old Jun 24, 2011 | 06:33 AM
gvulakh's Avatar
gvulakh
A little wet sand and buff should take it right out. I would stop and get a grease pencil. Circle the spots for them so they know where to look. Nobody knows your car like you.
Old Jun 24, 2011 | 06:35 AM
stein's Avatar
stein
Yes, it will buff out. I found several spots on a truck I bought that they touched up and it buffed out rather easy but hand.
Old Jun 24, 2011 | 06:44 AM
Driven1's Avatar
Driven1
Professional
clay bar and quick detailer. Pretty easy if it indeed is just over spray on an unprepped finished surface.
I wouldn't be terribly upset. Unfortunately it's WAY to common.
Old Jun 24, 2011 | 06:55 AM
TJGILROY's Avatar
TJGILROY
i'm glad to see other people feel my pain, to stein, after washing i saw these spots and tried to quick wax them out and it did no good so maybe their shop tools will have a better effect
Old Jun 24, 2011 | 07:03 AM
verdict.'s Avatar
verdict.
Great advice.
Old Jun 24, 2011 | 07:09 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Agreed... Have them do it, it's a lot of work.
JERZ350's Avatar
JERZ350
Use a clay bar on the car. It should take that out. My whole hood had overspray on it, the claybar took all of it out. Just make sure you wash area good before you use the bar. Then apply a coat of wax when you're done.
Follow the directions that come with the kit, spray the lube and then use the bar, put some elbow grease into it too.
Old Jun 24, 2011 | 07:19 AM
TJGILROY's Avatar
TJGILROY
i will do this if they don't get it all, like i said, you have to be in the right light and angle to see the spots to begin with, but when you do, you're like "yuck"
Old Jun 24, 2011 | 09:00 AM
TJGILROY's Avatar
TJGILROY
dropped it by the shop, picking it up after work...wish me luck!
Old Jun 24, 2011 | 09:07 AM
kno's Avatar
kno
i agree with everyone, take it to the shop, they faked up they need to fix it end of story. ive taken my front nismo bumper 4 times to get it fixed due to over spray and little bubbles on my paint. hell, you paid good money demand for a fix.
-ps if you try to fix it and you screw up they can deny that the damage or error was their fault.
Old Jun 24, 2011 | 09:23 AM
TJGILROY's Avatar
TJGILROY
yeah, that's exactly what i was thinking so i didn't try too hard and am giving them a chance to make it right
Old Jun 24, 2011 | 01:34 PM
TJGILROY's Avatar
TJGILROY
*update* got it back, in the sunlight the blemishes aren't there.... the rear bumper is sheen shine and then when it gets parked in the garage under indoor lightning and especially with a flashlight, the marks are still there?? it is even in some areas a different texture when you rub your finger over it??? what's the next thing i should do, hold their hand while they take it back in the shop???
Old Jun 24, 2011 | 01:38 PM
verdict.'s Avatar
verdict.
If you are not satisfied with it, take it back. I understand that mistakes are made, but you paid good money and you should be satisfied with the work.
Old Jun 24, 2011 | 01:39 PM
gvulakh's Avatar
gvulakh
They probably just used compound and then polished it. Sounds like it needs to be wet sanded. More work and time that they did not want to put in.
Back to the bodyshop you go.
