removing tint/paint from tail lights
Old Jun 29, 2011 | 09:20 AM
albe070z's Avatar
albe070z
Default removing tint/paint from tail lights
Hey guys,
My tail lights are blacked out but the tint/paint (not sure what it is) is faded and i want to remove it. Makes the car look bad from.the back
Just wondering what i can use?
Ill most likely fade them out afterwards again.
Thanks
Old Jun 29, 2011 | 09:56 AM
NissanTracker's Avatar
NissanTracker
Just slightly damp a small section of a shop rag with paint thinner and rub away. Dont use too much to the point its dripping. After, wash with soap and water.
If its tint, get yourself a blow dryer. Heat up on about 4-5 inches away and see what you can pull off by hand. Then use paint thinner like the first step or "Goo-gone" to remove the adhesive.
-NissanTracker
Old Jun 29, 2011 | 10:44 AM
albe070z's Avatar
albe070z
Ill give that a try. I appreciate it.
Old Jun 29, 2011 | 12:22 PM
shaddy-z.'s Avatar
shaddy-z.
Materials needed(if paint):
1500 grit sandpaper
Wax
Water hose
Time
Keep your hose on the headlight while you sand away and it should take about 20 minutes each or so. Then wax them after you're done.
Old Jun 29, 2011 | 12:43 PM
350ZTheStandard's Avatar
350ZTheStandard
Just buy another can of Night Shades and re shoot the tint, wha la presto all pretty again.
Old Jun 29, 2011 | 05:45 PM
albe070z's Avatar
albe070z
Thanks all for the different ways on going about it.
Old Jun 29, 2011 | 05:48 PM
FacePalm717's Avatar
FacePalm717
Acetone.... comes right off...then just use some rubbing compound and it looks like new.
Old Jun 30, 2011 | 01:33 PM
bmccann101's Avatar
bmccann101
i use 2% milk when wet sanding.
( please dont take my advice)
Old Jun 30, 2011 | 02:10 PM
JaE35z's Avatar
JaE35z
i used goof off, came right off with a paper towel
Old Jun 30, 2011 | 06:15 PM
TehkMob's Avatar
TehkMob
Use mineral spirits, Its not corrosive to plastics, DONT use acetone.
Mineral spirits with a sponge, will come right off, wash with soap after.
Acetone pits plastic, Thats why you dont pour it down sinks, It eats away the PVC
Old Jul 1, 2011 | 01:18 AM
R350Zz33's Avatar
R350Zz33
gasoline takes night shades right off
Old Jul 1, 2011 | 02:40 AM
FacePalm717
There's acetone in mineral spirits. I used straight up acetone and it came right off and there was no damage.
Uriyo_
Sep 8, 2021 08:46 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
