Fast blinkers after LED's in headlights
Old Jul 30, 2011 | 10:49 AM
ZJoe's Avatar
ZJoe
Default Fast blinkers after LED's in headlights
I've got an 03 and upgraded with new 06-08 headlights. A buddy painted the housing black and put in an LED blinker and an LED driving bulb. I'm also running the Clear Corners LED reflectors with full time running lights and blinkers.
For the first several weeks everything worked fine but over time my passenger side blinker started blinking faster than the driver's side. At first I would pop the hood and jiggle the wire attached to the back of the blinker and it would work fine but soon after it would start blinking faster again. Now no matter what I do it just blinks fast.
The LED's are wired into a capacitor and work fine on the driver's side. Would this be a ground issue or what? Any wiring experts got some input for me?
Thanks in advance.
Old Jul 30, 2011 | 11:42 AM
user 92720's Avatar
user 92720
I have white LED blinkers installed on my 06-08 headlights also. As soon as I put them on, it started blinking fast. When I turn on emergency lights, though, it's at a normal speed. When I put the OEM yellow blinkers back on, everything worked fine. If it's LED's, it's SUPPOSED to blink fast unless you mess with the wiring to adjust it and get it to work properly. It's no biggie, I got used to it.
Thanks in advance.
Old Jul 30, 2011 | 11:57 AM
RMichael's Avatar
RMichael
You have to run a load resister where you replace with LED from what I understand (or you get that crazy blink).
Old Jul 30, 2011 | 12:25 PM
Al Kapwned's Avatar
Al Kapwned
Google "Rice Blink"
Old Jul 30, 2011 | 02:42 PM
RMichael's Avatar
RMichael
Originally Posted by Al Kapwned
Google "Rice Blink"
I tried and all I got were sites dealing with Condoleezza's trips to Asia.
Old Aug 2, 2011 | 06:07 AM
ZJoe's Avatar
ZJoe
Ok, it seems to be fixed now finally. I found that when I'd move the wire running between the load resistor and the black wire out of the blinker then it would blink fast or blink normally. This told me it was a simple connection issue so I took it apart, cleaned up some of the sealant used the first time around for the connections (way too much), and used electric tape to hold it together. Problem solved.
Old Jan 9, 2012 | 11:42 PM
Delta_two-Niner's Avatar
Delta_two-Niner
I know it's been a while but i didn't want to start a new thread for this, not yet at least.
I just bought some LED turn bulbs and found that they do the rapid blink thing....no big, i went out and bought some 6ohm-50watt resistors. I installed everything and found that...No change ! still got the fast blinking on both sides this is how i wired it:
http://i1012.photobucket.com/albums/...it/wiring1.jpg
Please help
Old Jan 10, 2012 | 09:31 PM
FliPPER_Z's Avatar
FliPPER_Z
Please help
Did you replaced both front and back? If so , if you might need to and an extra resistor per side.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
