sti lens on an 05
Old Aug 1, 2011 | 12:26 PM
bjjbadboy's Avatar
bjjbadboy
Default sti lens on an 05
Hey im sure this has been asked im just not finding it in my search and only have limited pc access. I am opening my headlights up again gonna black out maybe play around with some demon eyes and what not but while I am in there wondering if I can use the sti lens on my 05 headlights?? dont see why not? if so any body know cheap places? thanks
Old Aug 1, 2011 | 02:11 PM
Saudi's Avatar
Saudi
i know theres a walk through that gives the website for them... i just did it on my 07 lights ... not sure if 07/06 are the same, but yeah they are available... search next time...
https://my350z.com/forum/body-interi...eadlights.html
Old Aug 1, 2011 | 02:48 PM
kevincat's Avatar
kevincat
You cant use the sti lens on the 05. 06-08 headlights are different than the 03-05
Old Aug 1, 2011 | 03:22 PM
mr. sparco's Avatar
mr. sparco
http://www.theretrofitsource.com/
Here's a place that sells lens and other parts. The sti lens is too large for the 03-05 headlights, you'll have to do a retrofit.
Old Aug 1, 2011 | 09:57 PM
gregom's Avatar
gregom
Yeah the 03-05 are hybrid projector/reflector design. The projector is much smaller than your standard projector. I'd do a retrofit... put a full size projector in. Check out www.hidplanet.com forums for ideas.
Here's a pic of 03-05 projector compared to a standard sized projector.
Old Aug 2, 2011 | 07:30 AM
BoomerZ33's Avatar
BoomerZ33
i don't think anyone's ever done this retrofit before. props to you if you're able to do it. your gonna love the sti lense's clarity.
Old Aug 2, 2011 | 07:44 PM
gregom's Avatar
gregom
What retrofit? Sounds like you have something specific in mind... It is impossible to fit an STi lens in a 03-05 projector, completely different design as you can see in my pic. I've already done a general retrofit, my 04 headlamps have been retrofitted with BMW e46 bixenon projectors, they perform closely to the 06+ headlamps. However I think the 06+ Z headlamps still perform better than the BMW e46 projectors.
Old Aug 3, 2011 | 05:24 AM
BoomerZ33's Avatar
BoomerZ33
i know that yes it's impossible. what i meant was doing some custom fab work and fitting an 06-08 projector into an 03-05. i've never seen that done before. it may even be less costly than sourcing a set of 06-08 headlamps (new or used).
Old Aug 4, 2011 | 05:24 PM
gregom's Avatar
gregom
I'm not sure where to buy the specific projector that is in our 06+ Z's. It would be just as easy to retro any other number of brand of projector into the headlamp. No real reason to go specifically with the one that comes with the Z. In fact there are several other brand or projectors that are considered to perform better than the ones in the Z. If your going to do custom fab work might as well put in the best projector you can get, and the one that comes in 06+ Z's isn't the best. No matter what projector setup you got, it would most definitely cost less than getting new 06+ headlamps.
I definitely recommend a retrofit to anyone who has good craftsman skills and can fabricate and manipulate material needed to make the headlamps look good after switching to different projectors.
Workshop12
Mar 23, 2020 01:45 PM
Morris
Jul 5, 2003 12:28 PM
ethan84ae
Apr 6, 2003 05:38 AM
denic79
Mar 27, 2003 07:53 AM
steve72852
Cleaning & Detailing
Feb 7, 2003 08:26 AM
