CF Hood with Dampers?
Old Aug 23, 2011 | 06:52 PM
X-Out's Avatar
X-Out
Default CF Hood with Dampers?
Alright guys, I just bought a CF hood from Carbon Creations and bought the Evo-R Hood dampers. I didn't realize until just now that using hood dampers with CF hoods is not recommended. Do you think that using the hood dampers on my hood would warp/damage it, or do you think it would be okay?
If it seems too risky, are there any hood dampers that are designed specifically for lightweight hoods? I haven't had much luck finding any via Google.
Thanks in advance.
Old Aug 23, 2011 | 06:53 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
I have NRG dampers on mine, they made a special set that was 2/3 the pressure for CF hoods.
Your hood will flex with full strength struts.
Old Aug 23, 2011 | 06:55 PM
gvulakh's Avatar
gvulakh
Found via google
http://www.getnrg.com/products/under...s-carbon-fiber
http://www.evasivemotorsports.com/me...0Z_Accessories
Old Aug 23, 2011 | 08:02 PM
X-Out's Avatar
X-Out
expensive! I guess I'll get these and list the ones I bought in the marketplace once I get the postcount/90 days. Thanks guys.
Old Aug 23, 2011 | 08:43 PM
Bmurray350z's Avatar
Bmurray350z
why
Old Aug 24, 2011 | 10:56 AM
X-Out's Avatar
X-Out
why
Because I like the look of it.
Old Aug 24, 2011 | 11:42 AM
Bmurray350z
^ Lmao
Old Aug 24, 2011 | 11:56 AM
bmccann101's Avatar
bmccann101
at least hes honest.
NRG +1.
i display my poorly fitting VS proudly w the stock prop rod.
Or i just take it off to work and use it to make a fort roof for my pets as they watch my needless toil.
Old Aug 24, 2011 | 11:58 AM
bmccann101's Avatar
bmccann101
besides, if you rock a carbon hood, youll snap it when you try to hold on to it as its being stolen.
Apparently when you go to China.
Old Aug 24, 2011 | 12:14 PM
BoomerZ33's Avatar
BoomerZ33
i used to use these on my CF hood without any problems:
http://www.thezstore.com/page/TZS/PR...z08c02/30-8312
Old Aug 24, 2011 | 06:21 PM
bbs350z's Avatar
bbs350z
why
theres probably like 75% of modded z's w/ cf hoods. even the ones with vents dont really do sheit. and the additional weight savings is minimal at best. same could be said about anything, wheels, brakes, aero etc on a street car. theyre never used to their full potential and are mostly for looks.
Old Aug 24, 2011 | 06:35 PM
Bmurray350z
i think it's pointless and looks tacky. but to each their own.
Old Aug 29, 2011 | 08:48 AM
PrimeX's Avatar
PrimeX
Nice! I have these on order but they won't be here for another 3 weeks.
Old Sep 8, 2011 | 04:05 PM
Travic's Avatar
Travic
This from the guy with a stock looking Z go figure. Looks just like every other Z good Job
Old Sep 8, 2011 | 08:04 PM
Saudi's Avatar
Saudi
lol... people and opinions... everyone has one! but like *** holes, you shouldn't share it
Old Oct 8, 2011 | 03:20 PM
tkuntz's Avatar
tkuntz
Default Hood Damper Question's....please help!
So recently i have been looking for a set of Hood Dampers.
My plan is to get a carbon fibre hood and i noticed that tein says not recommended for carbon fibre hoods, now does anyone know why that is?
Also has anyone heard of the brand NR>G Innovations, and if so how good is the brand its self, is it mainstream or just a junk brand.
If anyone could help me out that would be great thanks.
Old Oct 8, 2011 | 04:23 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
The hood will bend when you close it and may cause the carbon to crack. Carbon hoods aren't lighter than the OEM and the fitment is usually garbage. I have a set of NRG's and they work great, keep in mind I have an OEM HR hood.
Old Oct 8, 2011 | 04:42 PM
R350Zz33's Avatar
R350Zz33
carbin fiber not worth they money i have the evo-r 2 step hood dampeners with the carbon fiber look.
Old Oct 8, 2011 | 05:25 PM
aderossett9's Avatar
aderossett9
Default Too strong
the teins are actually strong enough to push the bolts straight off the hood when down and yeah crack the carbon fiber NO BUEANO
just get some low pressure ones from a local store ( advance,auto zone) and they will do fine... i also jsut had my VS3 hood pull itself apart from the fiberglass reinforcement and slam back into the windshield and roof , hood pin that **** for sure
Old Oct 8, 2011 | 08:40 PM
X-Out's Avatar
X-Out
I'm using the NRG ones on my CF hood and they work fine. No warping so far. They have 2 types, one for normal hoods and one for lightweight hoods, just be sure to get the right ones.
As has been said, the CF hood is not much lighter than the stock hood and the fitment really leaves a bit to be desired, but I sport mine proudly and if it's a look you want, go for it.
The NRG dampers work just fine. Also, if you're really scared of warping, I've heard of people using just 1 damper, but I don't have any experience with that.
Also, be sure to get some hood pins. You don't want to risk what could happen without them.
