how to change the side marker reflector
Old Dec 21, 2003 | 03:58 PM
xsmallpaulx's Avatar
xsmallpaulx
Default how to change the side marker reflector
hello, does anyone know if you have to take the wheels of to change the side marker reflector on the front bumper. and how do you get to them to change them. thanks
Old Dec 21, 2003 | 06:37 PM
bigdaddy's Avatar
bigdaddy
you do not have to take the front wheels off. however, you do have to take the bumper off. search the site under front bumper removal. there should be at least one thread with pictures of how to do it. it is pretty simple, just 11 bolts, 4 screws and a bunch of pop rivets. once the bumper is off, its very self explanatory.
sean
Old Dec 21, 2003 | 08:19 PM
orhanz33's Avatar
orhanz33
it's real easy if you take the bumper off, but it can be done w/out it....just get the car on ramps, look underneath and take off all the bolts/clips you see on that front diffuser (aero package) and take off enough from the wheel well to get your hands in there w/ a screwdrivers and unscrew them...the driver's side is easy, the passenger side takes FOREVER!!! there's a fluid tank in the way, i even got the special tool that was recommended and it was still a ***** to take out...a lot easier to just take off the bumper....
Old Dec 22, 2003 | 07:52 AM
kitkos's Avatar
kitkos
Step by Step Instructions on installing Side Markers is HERE
You do not need to remove the entire bumper but it does make it a little easier on the passenger side due to the window washer reservoir. I did mine without removing the bumber.
Old Dec 22, 2003 | 08:26 AM
Boogak's Avatar
Boogak
I just changed mine out yesterday, I did not have to take the wheels off, just turned them all the way to 1 side. The driver side was insanely easy, just loosen the wheel well and bend it back a bit for some room to work.
For the passenger side, I had to loosen the wheel well off even more and loosen the front bumper (but not completely take it off) so I could bend it back a bit for room to maneuver. However after having done it once, I could probably change it again in under 30 minutes now.
Old Dec 22, 2003 | 11:40 AM
xsmallpaulx
thanks everybody for the information, i guess ima going to do mine tonight ill let you guys know how i did
Old Dec 24, 2003 | 06:16 AM
sgt_bo's Avatar
sgt_bo
Where can i get the LED side markers. I want to get Blue for a Blue 350Z. How hard is it to wire the LED and hwo long should it take.
Thanks
Old Dec 24, 2003 | 06:49 AM
yobri's Avatar
yobri
Thanks
Ares from this forum should have what you inquire about.
Old Dec 24, 2003 | 08:00 AM
ares's Avatar
ares
Veteran
Thanks
I can help you out with that. its about 10-15minutes longer to install them with the wiring than without. once your in there to install the reflectors anyway the wiring is a snap.
Justin100
Nov 25, 2021 06:26 AM
kyin
Oct 15, 2015 05:54 AM
