Has this ever happened to anyone's headlights before?
Old Dec 30, 2011 | 08:07 PM
NJVinny350z's Avatar
NJVinny350z
Default Has this ever happened to anyone's headlights before?
Ok, well I bought my Z around May, and my headlights have been like this since I got it. There appears to be lots of little scratches on the plastic of both of my headlights (see pics below).
At certain angles you can't even see it, but personally it bothers me and I would like to know if there is anything I can do to fix this. Basically, I'm looking for replacement plastic for the outside of my headlights.
Eventually I plan on getting 06+ headlights anyway, but for the time being, if anyone could suggest an affordable way to fix this, I'd appreciate it.
Old Dec 30, 2011 | 08:15 PM
805350z's Avatar
805350z
http://www.youtube.com/watch?v=-cVbw8RZOfM
But for real.. there are little monsters in your headlight, burn and replace.
Old Dec 30, 2011 | 09:25 PM
Glex25's Avatar
Glex25
Did you ever baked your headlights?
I have seen cracks like that only if someone has left the headlights in the oven for too long or used too high a temp
Old Dec 30, 2011 | 09:52 PM
NJVinny350z
Nope.
I bought the car with them like this. The guy I bought it from had tint over the headlights so I really couldn't see them until I took the tint off.
Old Dec 30, 2011 | 10:05 PM
Waiz's Avatar
Waiz
Originally Posted by NJVinny350z
Nope.
This is exactly why I keep telling people not to tint their headlights.
Try and purchase one of those headlight restoration kits you can get at Pepboys and see if it helps. If it doesn't help just keep an eye on the marketplace and upgrade to the 06's.
Old Dec 30, 2011 | 10:22 PM
DaProdigy's Avatar
DaProdigy
happened to me when i installed lens film for protection a few years back in the summer time... non repairable as far as i know.
Old Dec 30, 2011 | 10:56 PM
NJVinny350z
I'm 99% sure the tint was added on there to hide the cracks. When I saw the pictures on the original cars.com posting, there was no tint on the car. When I showed up to look at it he had tinted them along with the taillights and even the top of the windshield ().
I actually noticed it through the tint about a week after buying the car, but didn't think it was a big deal. Like I said, it's only visible from a few angles when you get very close.
I figured it was non-repairable, just posted to make sure. Just gives me more of a reason to upgrade to some 06+ headlights I guess.
Old Dec 30, 2011 | 11:20 PM
f-350z's Avatar
f-350z
have the same thing with my 08 headlights (blackedout headlights with eye brows)
Old Dec 30, 2011 | 11:31 PM
Looks like flex fracturing. Plastic, when flexed, will fracture along weak lines that are part of the molding process.
Old Dec 30, 2011 | 11:36 PM
NJVinny350z
I guess I'm not alone.
Hmm. Any idea of what could have caused that to happen?
Old Dec 31, 2011 | 12:20 AM
midz350's Avatar
midz350
Happened to mine too.
I think its because when you put something on the headlights (tint, eyebrow..) it will heat up the Plastic more and this happens.
Old Dec 31, 2011 | 01:50 AM
A film that expands and contracts at a different rate than the plastic.
Ultra violet radiation.
Deficiency in the molding process.
Old Dec 31, 2011 | 03:43 AM
gixxert's Avatar
gixxert
my 03 had it really bad i had to replace the headlights there was no fixing. i had my roommate sand and buff them trying to get it out but no luck
Old Dec 31, 2011 | 09:22 AM
tam_anh's Avatar
tam_anh
My headlights had this issue too. I think because I parked my car out door most of the time. The sun will either make the lens haze or give them these stretch cracks. Time to upgrade your headlights.
Old Dec 31, 2011 | 10:49 AM
marques1's Avatar
marques1
stress fractures no way to fix it, just going to have to replace it.
Old Dec 31, 2011 | 01:22 PM
Z Fo Sho's Avatar
Z Fo Sho
Buy one of the cheap ebay headlights and swap out the lenses
Old Dec 31, 2011 | 01:59 PM
cubs4worldseris's Avatar
cubs4worldseris
There is no OEM Nissan nor aftermarket plastic lens covers that be purchased.
Old Dec 31, 2011 | 02:12 PM
WillyP28's Avatar
WillyP28
Samething happened to my headlights. I bought a used set off ebay for $250 and had the guys at lightwerkz switch the plastic lens covers and repaint the housing. Not cheap but it was worth it.
Old Dec 31, 2011 | 02:18 PM
f-350z's Avatar
f-350z
not in my case, coz when i removed the eyebrows for repaint, i found the area below them has no single crack, but only around the eyebrow area
Old Dec 31, 2011 | 02:33 PM
sk26dett's Avatar
sk26dett
Yea they're caused by overlays, same thing happened to mine. I ended up buying a pair of base headlights and swapping the plastics. Don't buy the $199 ebay crap, i hear fitment is terrible.
