350Z carbon Fiber rear Diffuser
Old Dec 30, 2003 | 10:30 PM
  #61
jeffrey's Avatar
jeffrey
Originally posted by Blownaway
TOURING "PLUS" :: SIX-SPEED :: SILVERSTONE/CHARCOAL
NISMO S-Tune Suspension w/sways
STOPTECH FRONT BRAKES - 13.1" Slotted Rotors w/BLACK ST-40 Calipers
Gunmetal VOLK LE37T - 18x8.5 +30 & 18x9.5 +35
Kumho Ecsta MXs :: 245/40/18-275/40/18
30% Tint
Passport 8500 Hardwire
SKiDaZZLe® Grounding Kit
STOCK air filter
JDM Sport Horns
REEN CF emblem fills
Evil
Looks like your one of the heard.
OMG! JDM Sport horns?! Must add HP!! CF EMBLEMS?!?! OHGODRIIIIIIIIIIIIIIICCCEE!!!
Of course, I'm just kidding.
Articfury is right on the money.
Old Dec 31, 2003 | 05:35 AM
  #62
droideka's Avatar
droideka
The CF fills are ABSOLUTELY rice, I will not defend that, but they only cost twenty bucks. The horns? They're loud and scare people. The grounding kit? Doesn't make any power difference on my car, but does smooth out the idle. I had a very rough idle before the kit went on.
Old Dec 31, 2003 | 05:56 AM
  #63
droideka's Avatar
droideka
Originally posted by articfury
Beyond that, if you don't like it, and don't want to provide constructive beneficial input, move on. If you feel it is your destiny help save people from themselves (seems like a strange roll for Droid ) try the constructive input I mentioned above.
Back to the thread,
Any new info?
D
It is a strange role for me, but for every person that I can convince to go to the track, just one time, that's one less person that we'll have to read about who spun their Z in a corner and ****ed up their car.
And for the record, I know how abrasive my first post was. It was not constructive in the least and the absurdity of this diffuser pushed me over the edge.
Old Dec 31, 2003 | 11:14 AM
  #64
MY350Z.COM's Avatar
Originally posted by droideka
First, I am a dick.
I can vouch for that!
Old Dec 31, 2003 | 12:44 PM
  #65
Ultimateone's Avatar
Ultimateone
uh,
Lets go back to the original thread!
Jay any more info
Old Dec 31, 2003 | 05:06 PM
  #66
PhoenixINX's Avatar
PhoenixINX
Originally posted by articfury Actually, Phoenix, as has been documented on this board before, the grounding kits do add measurable amounts of power. Moreso than some so called CAI.
I dyno'd my grounding kit.
Zero gain. Which if you have been able to break physics and measure an amount of nothing, then sir you are correct... the gain WAS measurable!
They do look nice though!
Old Jan 1, 2004 | 05:41 PM
  #67
supra crazy's Avatar
supra crazy
if i get the rear diffuser a peice of flat metal and a top secrete front diffuser it may work?
Old Jan 2, 2004 | 10:21 AM
  #68
articfury's Avatar
articfury
Charter Member #55
Droid,
Your efforts to get people out to the track are valiant, on this I agree with you.
PS
Your not as much a dick as you would have everyone else here believe.
Phoenix,
Nice quip. You do realize, that your car is not the only car that has ever used a grounding kit, right? Others have dynoed and posted repeatable numbers. Maybe they were posted when you were banned Additionally, the benefit that Droid mentioned of smoothing out the idle is worth the cost alone.
Another thing that I didn't point out to Droid's original post. Because of the attention that Nissan paid to the airflow under the 350Z, especially on the aero package equipped cars (i.e. Track) a properly designed diffuser very well could show benefits at the track. I am not sure though how the add downforce at the rear would affect the turn-in on higher speed corners. The front might be a bit loose. Trial and error is the only way to find out without wind tunnels and major software. A front diffuser, ala Top Secret, would probably be a nice complement to a rear diffuser like this one. That might help the front/rear balance.
D
Old Jan 2, 2004 | 02:43 PM
  #69
Chebosto's Avatar
Chebosto
D
you dont necessarily have to adjust the front end of the car's underbody to take advantage of a rear diffuser.. the main goal is to smooth as much as the air flow as possible for the air to exit the underside of the car nicely.. you've got alot of things to make air turbulent. you got exhaust pipes bending here n there. rear suspension moving... and to those ppl that went to dual exhausts... you now get rid of nissan's stock rear diffuser-.. if you look at it, there is a triangular piece that comes out , extending the front of the muffler as close as possible to the rear axle.. that is to start channeling as much of the air as possible to flow over the smooth surface of the stock muffler.
granted there is probably no benefit of adding any type of diffuser to the stock exhaust.. there is already one! all you really need to do is add to end pieces to make sure the air flow is straight and out. instead of leaking to the sides and gettting mixed up with the airflow from the rear tires.
i see no reason NOT to add one for those with the angled injen SES or dual RSR or whatever.. its just replacing what was originally there..
you can get nearly the same affect of all of this by lowering the car a little more in the front than the rear.
you dont have to be driving 200 mph for this thing to work. it will work at any speed. you just will feel lesser of the effects. what probably is more imporant is flat road surface for it to work with.
Old Jan 8, 2004 | 08:49 AM
  #70
toykilla's Avatar
toykilla
any new info? where are the pics of the rest of the diffuser?
Old Jan 13, 2004 | 09:08 AM
  #71
toykilla's Avatar
toykilla
bumpy
Old Jan 25, 2004 | 06:16 AM
  #72
toykilla's Avatar
toykilla
i guess this project was dropped
Old Jan 25, 2004 | 07:13 AM
  #73
Ultimateone
No Cheb is a busy guy and wouldnt waste all this time with R&D....it will come out
Old Jan 25, 2004 | 10:59 AM
  #74
MY350Z.COM's Avatar
this is EVO-R's thread, not Cheston's.
EVO-R tends to take a long time on their projects, like those LED lights. So I wouldn't expect these out anytime soon.
Old Jan 25, 2004 | 11:06 AM
  #75
Ultimateone
Oops yup this is Jay's thread
Old May 2, 2004 | 03:19 PM
  #76
spdu4ia's Avatar
spdu4ia
bump^ i WANT IT
Old Jun 23, 2004 | 01:36 PM
  #77
SEzzz's Avatar
SEzzz
BUUUUUUUUUUUMP
Old Jun 23, 2004 | 04:15 PM
  #78
JDMZ33's Avatar
JDMZ33
Vendor - Former Vendor
I have test fitted the one shown. They really look great. But it makes the rear clearance very low. I would suggest use it for show car only. I don't want to see anyone waste it by the car behind you. hehehe...
Old Jun 23, 2004 | 04:43 PM
  #79
spdu4ia's Avatar
spdu4ia
pics? expected date of completion?
Old Sep 11, 2004 | 06:38 AM
  #80
JDMZ33's Avatar
JDMZ33
I tested the rear diffuser on a 350Z with fuhisubo exhuast on it. The diffuser was alot lower than what I expected. Only leave you 2 inch ground clearence. The center part of the diffuser is too low. Anyone put this on, will crack it on the street. But would be cool for show cars and track cars. I didn't bother take a picture, since it is too low. Maybe work better on Z with Tanabe or Invidia exhaust. Those exhaust center part is clear out. I'll try to get a car with those exhaust on. - Jay
Project still on. not dropped. Like Vic said... "take a long time "
