Best way to get vinyl covering on tail lights off?
Old Mar 13, 2012 | 08:48 AM
Poison123's Avatar
Poison123
Google Bot
Default Best way to get vinyl covering on tail lights off?
Whats the best way to get vinyl coverings on the tail lights off if they've been on for 18+ months?
Old Mar 13, 2012 | 09:28 AM
cgkp0925's Avatar
cgkp0925
reheat and pull off. it will be a pain but there's really no other way.
Old Mar 13, 2012 | 09:57 AM
Poison123's Avatar
Poison123
Google Bot
Was afraid you'd say that. I can't get at the edges, so I'm having to scrape it little by little as I heat it up with a hair dryer.
Old Mar 13, 2012 | 10:22 AM
cgkp0925's Avatar
cgkp0925
It depends on the vinyl that was used too. Crappy vinyl will be even worse to get off then a 3M grade vinyl or equivalent.
If you're careful enough, you can use a razor blade to start a section. Be careful to angle it right so you don't scrape/gouge the plastic. Just slowly nudge it until you get a good size piece to grab on to. Then slowly pull while heating it at the same time. After everything is removed, you can use an adhesive remover to get any remains of adhesive off, then dry gas/isopropyl alcohol to wipe everything clean.
I work in the graphics/print business so I know the hardship that's ahead of you. Just be glad it's the tail lights and not the whole car.
Old Mar 13, 2012 | 10:38 AM
Poison123's Avatar
Poison123
Google Bot
Thanks. LOL I'd almost rather the damn car instead of the tail lights.
Old Mar 13, 2012 | 11:21 AM
ehsan's Avatar
ehsan
heat+patience+ plastic razors vinyl guys use.
Old Mar 13, 2012 | 11:29 AM
bbs350z's Avatar
bbs350z
if there is residue left from the vinyl, an adhesive remover such as goo gone or anything safe for plastics will work too
Old Mar 13, 2012 | 02:04 PM
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
that thing won't pump out enough heat. invest in a real heat gun, they're not that expensive and make working with vinyls much easier!
Old Mar 13, 2012 | 02:24 PM
Poison123's Avatar
Poison123
Google Bot
LOL I have one of those for working with heat shrink....just need to figure out wtf I did with it.
Old Mar 13, 2012 | 04:30 PM
JCITY's Avatar
JCITY
Heat and patience& tweezers.
Could be a bit by bit job.
3-M makes a adhesive remover that you can saturate the parts of the vinyl.
Its a mess.But to do it right,must be done in stages.
Old Mar 13, 2012 | 06:38 PM
Poison123's Avatar
Poison123
Google Bot
Got 2 of the 4 lights done...gonna need to refinish the tail lights on those two at some point. LOL I will get the heatgun and tweezers on the next two....
Uriyo_
Sep 8, 2021 08:46 AM
ablaine
Nov 29, 2016 10:13 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
