Just deleted my rear wiper & added an RDX Antenna
Thanks. Well whats next is, Ive been restoring the crap interior by repainting the damaged door handles and the scratched cubby door. The big mod will be comin probably in the next month or so with new wheels and lowering springs. Varrstoen es1.1.2's
Btw, what the hell happened to my attachments? Wais, did you mess it up?
Went ahead and stopped by Ace to do the wiper delete.
Ended going up with the "metal hole plugs" rather than the nylon plugs or faucet stoppers people seem to pick up from home depot/lowes. Reason being is they appeared to be more flat/flush like Kuhan's pics showed. These are located right next to the screws, just like you said.
The size I got was 1" for the rear wiper hole, and the 7/8" for the spray nozzle hole on the rear windshield. Went over the metal plugs with gloss black and hit it with a few coats of clear. After drying install took about 15 min.
The rear wiper hole was slightly smaller than the 1", so like another member on the diy thread I filed the hole slightly and the 1" fit snug.
Don't mind the dirtiness, I hadnt cleaned it off yet
The spray nozzle was next, and the 7/8" metal cap fit perfectly
There's a painted kt out there......
http://www.rearwiperdelete.com
I just decided to try the $2.80 total for spray nozzle and wiper hold plugs, rather than the $35. Especially since I already had the paint and clear sitting at home. Worked out ok for me.
Yep! I was considering getting that kit since they started selling it again recently-ish. I believe a member by the name "graffkid732" is making a good kit that others have recommended as well.
If you are going to do something, I think it should be done correctly. The deletes with the DIY cut down butt plugs look terrible, and IMO look worse than the wiper on the hatch.
Enjoy your gloryhole hatchbacks...
https://my350z.com/forum/body-interi...g-install.html
