Mounting Splash Guards
Old May 7, 2012 | 03:19 PM
Arvin89's Avatar
Arvin89
Default Mounting Splash Guards
I bought splash guards a while back and mounted them up with double sided tape. The way i taped it up didnt last very long the tape kept coming off on the inner side of the splash guard. I think im just not placing the tape correctly. I remember seeing a thread on the forum asking for a template for where to place the tape? And a picture was posted showing where to place the tape.
I was hoping someone may have some idea of what im talking about because i searched for it and couldn't come up with anything remotely close.
Id prefer to tape it instead of screwing it on.
Thanks.
Old May 7, 2012 | 05:40 PM
JCITY's Avatar
JCITY
??The splash guards need one screw into the wheel well rim.One under the car.
Whats the big deal?Use metal or self-tapping screws if you don't to mount in OEM
locations.I guess you can use 3-M.Surfaces have to be very clean.Also,I'd use
adhesion promoter wipes.
Old May 9, 2012 | 11:55 AM
Arvin89's Avatar
Arvin89
I found a set of mounting instructions. It says to use a #8 spring clip and a #8 tapping screw. I understand that I can use any size screw. But is the clip important? I decided to screw it on instead of tape.
Old May 9, 2012 | 12:26 PM
Tape is ghetto. The spring clip holds the screw in place. Look at the screw. Its a sheet metal screw.
Old May 9, 2012 | 02:48 PM
Arvin89's Avatar
Arvin89
I got the guards used a while ago. There's no screw or spring clip. So I asked my local dealer wheter they had it. And they don't sell it seperate from the guards, nor do they know what I could use to replace it.
So I was wondering how I could go about mounting without the oem hardware. Unless there's a place that sells just the screw and clip I'm gonna have to do a custom job myself.
Thanks.
Old May 12, 2012 | 05:47 PM
sluggoZ's Avatar
sluggoZ
Thanks.
This link shows the correct sizes for clips & screws for rear guards. Then go to your local hardware store or Home Depot or Lowe's for the screws & clips.
http://www.courtesyparts.com/rear-sp...-p-610257.html
Old May 13, 2012 | 09:13 AM
Arvin89's Avatar
Arvin89
Thanks guys. Ill be getting those on later today then.
Old May 20, 2012 | 05:45 AM
sluggoZ's Avatar
sluggoZ
Did everything go OK!!!!
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
