Plastic Engine Cover Heat Protectant Strip
Old Jun 25, 2012 | 12:11 PM
VO...'s Avatar
VO...
Administrator
Default Plastic Engine Cover Heat Protectant Strip
This weekend I was doing some upper plenum polishing and decided to pull off the engine cover panel to polish underneath it. What I found were the little strips of cushion, taped to the panel, were dry rotted and brittle. Consequently they made nasty stains on my polished upper plenum. After removing the stains with heavy elbow grease, I decided to replace the cushioned strips. Took a drive down to my local Autozone to see what I could find.
What I found was a roll of cork gasket material for $5.99:
http://www.autozone.com/autozone/acc...ier=67681_0_0_
I already had a roll of 3M double sided tape at home, so I measured it off and cut the strips to mimic the old ones. It's an easy little DIY project. I'm hoping the gasket material holds up to the heat. Here's some before and after pics...
Attached Thumbnails Plastic Engine Cover Heat Protectant Strip-2012-06-24_12-28-33_551.jpg   Plastic Engine Cover Heat Protectant Strip-2012-06-24_12-29-03_549.jpg   Plastic Engine Cover Heat Protectant Strip-2012-06-24_12-29-32_571.jpg   Plastic Engine Cover Heat Protectant Strip-2012-06-24_13-10-38_182.jpg   Plastic Engine Cover Heat Protectant Strip-2012-06-24_13-11-59_626-1-.jpg
Old Jun 25, 2012 | 01:19 PM
JCITY's Avatar
JCITY
You know,don't know if those cushioned strips on the engine cover actually serve
a purpose.Especially for heat protection.When I had my plenum polished,I installed
a CF engine cover.I used no gasket or cushioning in the install.
Its just fine.I'm thinking that the foam strips were there for more of a vibration
insolation rather than for the heat.
Old Jun 25, 2012 | 01:26 PM
VO...'s Avatar
VO...
Administrator
Its just fine. m thinking that the foam strips were there for more of a vibration
I believe you are 95% correct. 95% to cut down on vibration. 5% there to not have the plastic panel touch the plenum. Can we agree on this?
Old Jun 25, 2012 | 03:00 PM
bmccann101's Avatar
bmccann101
Let me use my slide ruler and I will get back to you on the precise calculations lol.
Old Jun 25, 2012 | 03:13 PM
VO...'s Avatar
VO...
Administrator
Hopefully you use an abacus. We don't want any wrong calculations...
http://www.youtube.com/watch?feature...OgLltWhgg&NR=1
Old Jun 25, 2012 | 03:27 PM
bmccann101's Avatar
bmccann101
damnit.. abacus trumps my slide rule.
k.
Old Jun 25, 2012 | 06:57 PM
realist alive's Avatar
realist alive
^ WTF
Old Jun 25, 2012 | 08:13 PM
jerryd87's Avatar
jerryd87
shouldnt have any issues with the cork, thats what i had on my intake plenum and throttle body(it was even used, left on from the previous owner lol.) and had no issues used to use it alot in my sbc's with no issues holds up great. it will deteriorate with time(but then again dosnt nearly everything?) but its easy to clean off
Old Jun 25, 2012 | 08:42 PM
bmccann101's Avatar
bmccann101
Yes make sure you moisten the strip before installation .. you always want to soak the cork and use both hands when working with it...
Old Jun 25, 2012 | 08:51 PM
bmccann101's Avatar
bmccann101
This thread... is ruined..
Old Jun 25, 2012 | 09:55 PM
jerryd87's Avatar
jerryd87
lol dont forget something to make it slick
Old Jun 25, 2012 | 09:57 PM
bmccann101's Avatar
bmccann101
Dude...the best snow skit ever. " yes my father.. he was di best cork soaked.." lol.
Old Jun 26, 2012 | 06:46 AM
VO...'s Avatar
VO...
Administrator
You sir, have brought me the LULz...
Old Jun 26, 2012 | 06:48 AM
bmccann101's Avatar
bmccann101
I aim.to please w unabashed comic relief..
3vilbunny
Jul 18, 2017 05:10 PM
ablaine
Nov 29, 2016 10:13 AM
